Need ignition help
I have an 82sc with a permatune unit, but have a coil. The car ran ok, but missed slightly. Yesterday, I replaced my Behru connectors with new ones. Tried to start the car and "No Fire" anyware. Did nothing else. anyone have any ideas, did I knock something loose? HEKP
Toga82sc
Old 02-18-2002, 05:41 AM
Early_S_Man's Avatar
Porsche Crest
You probably put the spark plug wires in the wrong holes in the distributor cap ... turn the engine over manually to TDC # 1 and start with #1 again.
Or, maybe you knocked the green cable that carries the trigger signal to the CDI/Permatune unit loose. Be very careful, as the connecyor for the green cable is fragile after years of exposure to engine heat!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-18-2002, 05:51 AM
Warren,
I only change out the connectors at the spark plug end.
Where does the green trigger wire run? I presume it connects to the coil. thanks for the quick reply
Toga82sc
Old 02-18-2002, 06:05 AM
Pull the HT lead off of the Dist cap and hold it no more than 4 mm from ground. While turning over the engine, it should spark. If it doesn't, go to http://www.permatune.com/Technical%20Support/Porsche/911.htm and perform the checks for the cds unit and coil. Like the previous posts stated, check for loose and/or corroded wires as well.
Old 02-18-2002, 06:34 AM
Porsche Crest
The green cable runs from the large magnetic pickup assembly around the distributor body to the CDI/Permatune unit.
Warren Hall, Jr.
Old 02-18-2002, 08:16 AM
