Removing Black Tar to install Strut Brace
I will be installing a strut brace later this week. What is the best way to remove the black tar- like material on the top of the strut tower?
A heat gun should soften it up enough to put in a brace.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Virginia Rocks!
Chip it off with a hammer and chisel.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
AutoBahned
you can replace with strip caulk
if you remove it all you may have water in the trunk |
I took off the parts then wire brushed them and wire brushed where it was on the car then touched it up later.
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
I'm getting ready to do the same. How did your project go?
Did you need to get a torque wrench? Did you replace the caulking once the brace was installed? Lastly.... Did you notice any difference at all once installed? I'm going to install on a 1989 cab? |
Northern Motorhead
I chipped mine off carefully with a wood chisel ...
There's no need to replace the tar once it's been removed,just make sure you touch up the spots where you may have scratched the metal ! Not sure if i could " feel " a difference,but technically it's supposed to work and keep your camber more constant. Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
The caulking goes under the plate,....around the perimeter of the shock opening underneath to make a seal. Plate gets put on top therefore no need to pour molten goo over the plate as the factory did.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Schleprock
That tar crap is a real pain and mess. I originally used a chisel/blunt flatblade screwdriver very carefully, but still managed to scratch the paint here & there. I say forget the chiseling because I tried the heat gun on another car and it worked excellent. Get the crud just hot enough to slightly start bubbling and then scrape it away with a plastic or wood scraper. Final cleanup with a suitable adhesive remover solvent will clean off the rest of the black. I prefer 3M general purpose adhesive remover. Nasty stuff, so wear protective gloves!
For caulk I used some rope caulk that is typically used for home window work. It's pliable and sticks where you want it to, but also easily removable. It's also weather resistant, since it's intended for window use.
Kevin L '86 Carrera "Larry" |
Flat Six
If you chill it first (I used a can of compressed air -- computer keyboard duster -- inverted so the liquid nitrogen-like stuff hits the tar) it'll chip off pretty easily and in fairly large chunks. YMMV, but worked well for me.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Like flat six said, try to chill it first, it will be very brittle after chilling it. If you can get "dry ice" which should be cheaper than the compressed air. Then you can use a Fein/Bosch or Dremel multitool to scrape it off.There is a post that shows how somebody used this tool to scrape the tar from a 911 lower panel.
I do not like to use a heat gun for this task, you make a mess and the hot tar sticks to everything and gives nasty burns if it touches your skin. |
Less brakes, more gas!
I heated 1 side with the heat gun... that didn't work too well and now I have a thin layer of black crap everywhere... the other side I used a dull chisel. The tar took some of the paint with it. I was not happy. Any way you do it it seems to be less than great results
![]() -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Schleprock
Gotta clean up the residue with a solvent like mineral spirits/paint thinner
AutoBahned
just leave it there!
why the rush to remove something that the factory engineers thought important??? |
Schleprock
It's only importance is keeping water out of the trunk. There's plenty of suitable alternatives that exist to seal up the strut mount area better than hardened tar.
Plus if you want your car to receive a proper alignment, those big 'ol chunks of crud MUST be removed w/out question.
abides.
I tried this too using bubble gum remover (probably the same stuff, just compressed CO2). It worked like a charm.
Graham 1984 Carrera Targa |
AutoBahned
Checked out
in theory you shouldn't have to remove much, if any, of the tar to do a factory alignment.
but in reality, pretty much every 911 in the US has been lowered, most of them significantly. So when you go to realign, you basically render the factory tarring useless, as the large washer plates move so much during the alignment. The movement causes the tar to chip off (by necessity), and the new placement of the plates after the alignment leaves gaps that the "old" tar doesn't cover |
Schleprock
What makes me say that is the crud is packed into the gaps and crevices of the strut mount opening in the chassis and locks the mount in place. In order to move the mount side-side or fore-aft, the crud has to be cleared away. Better to do it yourself than to let your alignment guy take his own liberty (aggravated because that junk is in his way, time is money, and chips away at it with whatever tool suits his fancy) and scratch your car quite nicely?
AutoBahned
All I can say is that what you describe is directly contrary to my experience with 2 cars. The newest was a '75; maybe things are different on your '87...
