G50 shifter wobbles in gear and clunks
All,
At the end of my drive Sunday I noticed the shifter would wobble in gear. I also noticed that when in neutral if I wobbled the shifter (typical neutral verification procedure) I could hear a clatter or clunking from about 1 foot aft of the shifter.
What did I break? The car has 83k miles.
Thanks,
'nutzzz
Old 04-05-2011, 11:43 AM
How about your shift tower bushings ?
Old 04-05-2011, 12:00 PM
You may have an issue with the plastic socket that holds the shifter.
Old 04-05-2011, 01:06 PM
+1 Did mine this past weekend, quick job and made a big difference.
Also, people have used a large o-ring in the tunnel to apply light pressure to the shift rod. You'll have to search for the details, but it was done to minimize shifter vibrations IIRC
Chris
'87 Targa
KTL KTL is online now
Schleprock
KTL's Avatar
That would be my diagnosis too. Snapped into the tail end of the shifter housing itself is a plastic ring that the main shift rod passes through. This is a guide ring that forces the shift rod to rotate instead of moving side-to-side. When that bushing completely falls apart, you can't select any of the following gears: 1st, 2nd, 5th and reverse.
These gears are selected by first pulling or pushing the shifter handle sideways, which makes the transmission shift rod rotate. The rotation is what engages the appropriate shift fork in the transmission to then select the aforementioned gears when you then push up or down on the shift handle. If that bushing is starting to fail, what you'll feel is the shifter flopping a bit because the bushing is no longer tightly capturing the shift rod and forcing it to instantly rotate
Kevin L
'86 Carrera "Larry"
Old 04-05-2011, 01:44 PM
Thanks Gents- I'll dig in this weekend and see what I see.
Old 04-06-2011, 06:27 AM
JMatta's Avatar
New bushings throughout make a world of difference. They wear very slowly and you don't even recognize it, until you install the new ones and think, why didn't I replace those earlier?
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 04-06-2011, 06:32 AM
G-50 shift tower bushings
This is my post about the bushings...some really good pics form another poster that were helpful
Old 04-06-2011, 11:04 AM
RETIRED
Joe Bob's Avatar
Check your trans and engine mounts as well...
2012 ML350 3.0 Turbo Diesel
Old 04-06-2011, 11:07 AM
