Send a message via Yahoo to asudds
Engine Stand Requirements for 3.2L
I am looking to purchase an engine stand for my 3.2L Carrera engine... any suggestions on low cost functional stands. How much and where to purchase would be of great help.
Aaron Sudds
Detroit
1987 911
Old 02-19-2002, 10:35 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Aaron,
I think the safest way to go is to get the 5 arm Porsche yoke to hold the engine Kinda expensive ($180) but it lets you work on the flywheel side of the motor while it's on the stand.
Go down to the engine stand section:
Pelican Tool Page
The yoke shaft is a standard size, so it'll fit in any old engine stand. A friend was able to locate a solid 1000 lb., four wheeled/legged stand at a local tool shop for $75.
Kevin L
'86 Carrera "Larry"
Old 02-20-2002, 09:20 AM
Friend of Warren
A regular engine stand will work. Do a search on this board and you will find at least two threads on the subject.
Kurt V
Old 02-20-2002, 09:33 AM
jabb's Avatar
I am using the Porsche Yoke on a $49.00 american engine stand.
Engine stand rated at 1000LBs The yoke fits perfect....
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 02-20-2002, 10:11 AM
cwood
Guest
Posts: n/a
I use the yoke and a norco brand stand
Look for one with 4 wheels in a H or C configuration.
The 3 wheel T ones have a tendency to be a bit scarry.
try the following to give you an idea of whats out there
www.norcoind.com
www.ontool.com tool sales
www.johndow.com
Old 02-20-2002, 10:52 AM
I also used a standard engine stand ($55 CDN on special) I than made up an adaptor plate from .25" steel, drilled 4 holes to line up with 4 engine/transmission bolt holes. Cut 4 spacer tubes about 2.5 " long to clear the flywheel and mounted the engine to the "kiss plate" bolted to the stand. The only thing I can't get to in this configuration is the flywheel, If I removed it before I mounted the motor I guess I could get access to the seal. I would have to do that job with the engine on the ground. Don't have any pics but if anybody is interested I could get one this weekend. I'm doing a top end job. Total cost about $70 CDN ( $43 US) WOW, After all the parts I'm buying from the States I finally get ahead of the exchange!
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 02-20-2002, 12:47 PM
