Schleprock
Front Caliper Inspection
Decided to reseal the front calipers (65k mi.) yesterday. Here's some pictures of the front caliper bores.
Inner pistons wanted to slide right out. Outers were pretty stubborn and didn't want to come out. Had to crank up the press. to 75 psi (way more than I felt comfortable with) to get those outer ones out. Sounds like a firecracker when those things come out. Word to the wise. Wear eye protection when doing this and have the pistons blocked with pieces of wood and clamps. The pistons come out of the bores in a BIG hurry. Can get pretty dangerous if you get careless/impatient. These things are toast. Open the wallet. The bores are scored pretty good. You can slightly feel the scoring with your fingernail. The caliper bodies are not bad looking. No rust or leakage. Only the dust boots were a little tore up, but I didn't expect the bores to be ruined like this. If anybody has any signs of brake dragging (my right front would groan a little when slowly turning right) you may have calipers like these. Kinda sucks really. Based on the exterior appearance, I wouldn't have expected the calipers to be garbage. Any opinions? Brakes are too important to take any chances. ![]()
Kevin L '86 Carrera "Larry" Last edited by KTL; 02-18-2002 at 07:56 AM.. |
What are you going to do?
Upgrade (930s or C2/C4) or stick with standard.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
I have heard mention of some places that restore calipers like this. They bore them out and then sleeve them to the specs. Anyone had experience with this? Seems better than tossing the calipers...
Doug '67 911 2.2 |
Schleprock
Just thought i'd post the pictures for all to see. Thanks
Kevin L '86 Carrera "Larry" |
