switch
A little off topic, but is that a "cut off" switch there? I like it.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
If you mean the O/1 switch?....that's an on-off switch for the trunk light.....for example, when you keep the lid open and don't want to drain the battery.....you know, like most modern cars have.... but is a head-scratcher for electrically-challenged Porsche to include ....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Formerly known as Syzygy
Will, you are undoubtedly correct. I've never really paid any attention to the actual numbers on pictures of people's data tags. I can only rely on the ones I have intimate knowledge of (my car). I guess that during assembly, the factory needed a number to identify the cars. In earlier stages of construction, perhaps they didn't yet know the ultimate destination of the car and the final complete VIN that would change depending on where the car was to be delivered. Maybe, only speculating here...
On yours, what are the numbers on the hood mounted stick on option code tag? Are they the ones with the chassis number or your VIN? Regardless of all this, except for earlier examples (starting from when I don't know) a North American car will have the vin mounted on the A-pillar and in the door jam. My Euro ROW doesn't have these, but has a stamped metal data plate mounted to the inside of the trunk on the passenger inner fender. The option code sticker on the hood also shows the correct VIN. There is another number stamped somewhere in the trunk area, I believe, but I don't remember where off hand.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Kevin(syzygy) says.... " I guess that during assembly, the factory needed a number to identify the cars. In earlier stages of construction, perhaps they didn't yet know the ultimate destination of the car and the final complete VIN that would change depending on where the car was to be delivered. Maybe, only speculating here..."
Answer...absolutely true. My paper tag on the underside of the trunk lid shows the proper VIN.
Thank you for such an informative info. I recently bought a US spec car here in Thailand. Dealer here have no knowledge to differentiate btw Chassis No. and VIN No. Of my car maybe because here both numbers have ZZZ on 4th 5th and 6th digits and 9th digits is usually the same, where as US spec from what I learnt here the VIN number Is slightly different on the above mentioned digits.
Is there a way for me to prove to dealer here that my car is clean and chassis number with WPOZZZ93ZGS050111 is correct and my VIN number WPOJB0931GS050111 is also correct and they are different like that from the factory. Is there a contact person I could write to in official Porsche of North America to verify this for me as of now the dealer here is reluctant to restore my car. Your advise would be very much appreciated. ![]()
Mine has one big difference..................
Porsche 911 3.2 Carrera Sport wheel & dash by Kevin Frost, on Flickr
83 911 Production Cab #10
From the Red book the "JB0" (and the "0" in the 12th position) in your VIN id your car as a 1986 Turbo US (WPOJB0931GS050111) J: Turbo Coupe B: US Engine O: Active Restraint (safety equipment) 7, 8 and 12th position): Porsche Model Type 930 The 1 in the 9th position in the VIN is a test digit for US & Canadian car (Z for RoW cars also found on the chassis # of all cars) The matching engine would be type 930/68 From Bruce Henderson book: That page (especially the last sentence in the red box) should convince anyone that work in this field but sometime it does not... Good luck, JJ https://www.amazon.com/Porsche-911-Red-Book-Specifications/dp/0760347603/ref=sr_1_1?ie=UTF8&qid=1474553118&sr=8-1&keywords=porsche+red+book https://www.amazon.com/Porsche-911-Performance-Handbook-1963-1998/dp/0760331804/ref=sr_1_1?ie=UTF8&qid=1474553199&sr=8-1&keywords=bruce+anderson [/QUOTE]
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
The difference in the stamped VIN numbers was addressed in a factory bulletin decades ago. My suggestion would be to tell them to contact Porsche through their normal channels and ask these questions themselves. It's their job to have all of the asnwers, or know where to get them. You shouldn't have to be the one to tell them how to do their job. JR |
Jacksonville, Fl
[/QUOTE]Not to highjack here, but Will I am dying to know what the switch on the upper left corner of the black shroud is for?
Alex Jacksonville, Fl '88 Carrera, Guards Red |
Visually, the ROW cars typically have side marker lights on the front fenders, and a red "fog" light under the rear bumper on the left. My ROW '81 SC does anyway
And like others have pointed out, 930/10 engine. That's the fun part
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Reiver
Motor ID...if it is stamped as a 64DXXXX (x's are the serial number) it is a US 930-16 180 hp.
if stamped 63Dxxxx it is the 930-10 204hp ROW
De Oppresso Liber Strength and Honor 5th Legion |
Not true for the first 3 years of the SC... only 81 and later. BTW, the '74 (not an SC, I know) had the skinny rear bumper pads in the US. Last edited by tcar; 09-22-2016 at 10:51 AM.. |
Indeed
![]() The other pages show "USA + Japan" and "California"
88 BMW 325 86 911 Turbo |
This is what i got from my the 911 turbo factory manual ![]() And my engine code sticker shows 93068-68G So i'm just confused.
88 BMW 325 86 911 Turbo Last edited by ncoder; 01-10-2025 at 01:47 PM.. |
Ah, there's more:
![]() Although I still don't see my /68
Insert Tag Line HERE.....
The OP has logged in for over 5 years.. lol.
Marc |
Refer to
https://www.stuttcars.com/porsche-911-engine-numbers-1965-1989/ They got the information out of the Porsche original parts catalogue, the V-pages in the front part of it: Porsche listed the VIN, engine and gearbox numbers related to the model years. Saying there's a bidirectional relation between model year vin, engine and gearbox number and you can decode the model year from the number too. https://www.porsche.com/usa/accessoriesandservices/classic/originalpartscatalogue/#911 Model Region Enginecode MY Code Enginenumber Tech. Displ Power 911 TURBO (USA) 930/68 1986 G 68G 00001>02000 6ZYL/3.3L 3.3L 209 kW 281 hp 911 TURBO (USA) 930/68 1987 H 68H 00001>05000 6ZYL/3.3L 3.3L 210 kW 282 hp 911 TURBO (USA) 930/68 1988 J 68J 00001>05000 6ZYL/3.3L 3.3L 210 kW 282 hp 911 TURBO (USA/CDN) 930/68 1989 K 68K 00001>05000 6ZYL/3.3L 3.3L 210 kW 282 hp So your 68G is a MY1986 930 US spec engine.
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
