Red dot on stud
Someone once told me why one wheel stud is painted red. Can't remember for the live of me why, but today I put new rims and tires on the car. The new tires have a red and a yellow dot on them. Is it possible that they should be lined up with the painted stud? Just a thought. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Navin Johnson
The valve stem should either be aligned with the red dot on the stud,or opposite it..
Or so I have heard.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
usually you mark a stud if there is a weight problem ... if the rim weights in correct in one position and off in others then you mark for alignment with your valve stem ....
With new rims and tires if you have a small shake in the wheel you may want to re clock your wheel one stud and try again ... then remark the stud then aligns correctly with your stem ..... Steve |
Used to be that the red dot on the tire was the heavy spot so it got mounted 180* from the valve stem. Don't know why the stud is marked. May be that the PO marked the high (or low)
spot on the hub.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
