Strut Brace versus Sway Bar
My 911T has neither up front.
Which one should a put on first ?
Old 02-20-2002, 11:16 AM
What are you trying to accomplish?
Nick
'85 Carrera
Old 02-20-2002, 11:19 AM
I am hpoing for a "tighter" ride overall, not necessarily only improved cornering/handling.
Old 02-20-2002, 11:26 AM
addictionMS's Avatar
sway bar for sure, only after you have tightened everything else up would I worry about the strut bar. First you might consider the condition of you shocks as well.
but always...tires make the biggest difference
Jim
Old 02-20-2002, 11:30 AM
Administrator
Jack Olsen's Avatar
Swaybar first, I'd say. A strut brace is really a finessing device, like turbo tierods. It's for that last few percentage points of adjustment. Swaybars are part of your overall foundation.
Old 02-20-2002, 11:38 AM
Friend of Warren
Here is the order in which I would do things:
Tires
Shocks
turbo tie rods
all new bushings
front and rear sway bar
upgrade torsion bars
strut brace
Kurt V
Old 02-20-2002, 11:39 AM
Steve W's Avatar
However if you do put in a front swaybar, you need to balance it out with a rear bar too, otherwise your fronts will be too stiff, and you will end up understeering. Swaybars though should come after you've already upgraded the shocks and springs. Bilstein sports will give your car a very nice tight ride - you may think as if you just added swaybars.
Old 02-20-2002, 01:20 PM
911 user
Milu's Avatar
Finish with the strut brace. In my experience you only feel the benefit of the strut brace in seriously fast mountain driving or on the track, the rest of the time it's just compromising luggage space.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 02-20-2002, 01:28 PM
davis911s's Avatar
Jim email me, I think I still might have the sway bar from the 70S I parted out
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 02-20-2002, 03:00 PM
Before doing anything make sure you have decent shocks.
The next would be to replace the torsion bars.
The next would be to install a sway bar. The sway bar is used to tune the suspension after you have selected the correct spring rates (torsion bar).
The strut bar goes between the front shock towers to keep them from moving. Doesn't make a lot of sense to have them secure when you've got worn out shocks, weak torsion bars, and an oversized sway bar. Strut bar should be fairly far down the list.
Old 02-20-2002, 03:57 PM
I agree with Don's checklist. While many install sway bars before torsion bars, installing springs first offers more dramatic (positive) changes in handling characteristics.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 02-20-2002, 04:26 PM
Hellgate's Avatar
Be sure to check out your bushings on the a arms and the shock bearing. On my old '69 they were original and replacing them made a huge difference. Netrix (sp?) is a very good option. Firmer than stock and much softer than polyurethane.
My car didn't have sway bars either, hard to imagine a P-car with out them, but adding them made a big difference; and the handling became tuneable, if you install them do adjustable ones. If you can only do one at a time do the front first. Begin by setting them full soft and adjust from there.
Another area people sometimes over look are wheel bearings. If your's are loose simplely adjust them, if they won't adjust, buy new ones. Makes a world of difference.
Pete
'02 996 - 285 RWHP!!!
Old 02-20-2002, 05:55 PM
Automotive Writer/DP
Randy W's Avatar
Yeah, I also agree with Sherwood. Everything else you do to the suspension will depend on what torsion bars you select. The spring rate will determine the shocks, since these dampen the springs. Then sway bars are selected depending on your springs/shocks and performance goals. This is also the order in which all the race team suspension guys I know tune 911s: 1) springs (depending on the track and weather), then 2) shocks and 3) sway bars (depending on driver style and how the car behaves). Strut bars can be felt on any 911 (more so on Targas), but they are way down the list of suspension mods.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 02-21-2002, 07:57 AM
