Back On The Road Again
WELL ITS OFFICAL, I JUST FINISHED THE OIL COOLER RELOCATION ON MY 87 SLANT NOSE CONVERSION. WHEN
PURCHASED IT WAS BEHIND THE LEFT REAR WHEEL AND NOW ITS IN THE RIGHT REAR BRAKE DUCT. I HAVE ADDED AN AFTERMARKET OIL COOLER FAN AND INSTALLED A MANUAL OFF/ON SWITCH. I ALSO CONVERTED FROM THE FIBERGLASS FRONT AND REAR BUMPERS BACK TO STOCK PORSCHE METAL COMPONENTS. ANYWAY ALMOST DONE EXCEPT FOR CUTTING THE BRAKE STRAKES SO THE FIT BACK INTO THE BRAKE DUCT OPENING. COULDN,T WAIT SO SUNDAY ASKED THE MRS. IF SHE WOULD LIKE TO TAKE A RIDE IN THE CAR SHE SAID WOULD NEVER RUN AGAIN, SHE REPLIES IN THE AFIRMATIVE AND I GO OUT TO DOUBLE CHECK ALL OF THE WORK I,VE PREFORMED SINCE SEPT 2 WHEN I PUT IT IN THE AIR. BRAKES BLED, OIL FULL AND NO LEAKS, WHEELS ON AND ALL LUGS AT 96ft lbs, TOP SHOCK MOUNTS TIGHT, BATTERY CHARGED, AND GIVE ALL THE BODY WORK A SHAKE TO MAKE SURE I TIGHTENED ALL THE FASTNERS AND JUST THEN THE MRS. EMERGES INTO MY GARAGE AND ANNOUNCES IS IT "ALL" DONE AND HAVE I CHECKED "EVERYTHING" I GIVE HER MY ASSURANCE THE BEAST IS READY FOR THE RIDE. I START IT UP AND BACK IT OUT, WATCHING FOR ANY SIGN OF ANOMALLY. PERFECT!! I LOAD HER UP AND BACK OUT OF THE DRIVE, DOWN THE STREET AND ONTO THE MAIN ROAD WHERE THE SPEED LIMIT IS 55 AND TAKE HER GENTLY UP TO SPEED. THEN TURN RIGHT AND HEAD UP TO THE MAIN ARTERY HIGHWAY 54 AND TURN LEFT AND START ACCELERATING UP TO THE POSTED 60MPH WHEN "WHAM" THE CONVERTABLE TOP DECIDES TO GO DOWN BY ITSELF IN LESS THAN A MILISECOND TAKEING MY BETTER HALFS 45 MINUTES OF HAIR STYLEING AND MY TOUGHTS OF A ROMANTIC EVENING WITH IT. ANYONE ELSE EVER FORGOT TO CHECK THE TOP HOLD DOWNS?? KEITH |
Senior Member
The top hold-downs on my coupe are so secure, I hardly ever need to check them. Same with the radiator and water pump brackets.
Glad you're "on the road again.' Happy motoring!
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
911 user
No. But I have driven off with the front lid not properly closed! Very exciting when you are overtaking and it opens. Explaining to my father whose 911 it was, was also quite exciting! (In all fairness to me, I was collecting the car from a dealer service and they gave it to me like that, however, I always check now!)
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
