SC Ray
81 SC Ray's Avatar
What happens when a front torsion bar breaks.
I am a daily driver kind of guy that drives his 1981 911 to work and back and everywhere else. My mechanic told me a couple of years ago that mine could not be tracked (I don't do track) because of some pitting, and that they should be replaced. I have the replacements - used ones off Pelican classified - in great shape. I have not put them in yet. But, I am still curious - does the wheel rub up on the wheelwell and destroy it? - does the tire shred as it tears up the metal in the wheel well, or does something stop the wheel from impacting? Do you lose control?
Thanks.
Old 05-16-2011, 12:10 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
I've never had a torsion bar snap, but I am sure if you did, you'd definitely know it immediately. Probably the suspension would collapse on that side. Yes, you might lose control.
Mark Petry
Bainbridge Island, WA
81 SC
Old 05-16-2011, 12:19 PM
RETIRED
Joe Bob's Avatar
Thru the body bar....prolly take out the gas tank and it explodes....
2012 ML350 3.0 Turbo Diesel
Old 05-16-2011, 12:27 PM
AutoBahned
RWebb's Avatar
repl. your susp. bushings too - old bushings allow the t-bar to rub and creates a stress fissure (aka, crack, riser for your search)
very dangerous to have one snap while driving
Old 05-16-2011, 12:31 PM
I think you mean sway bar. His problem is the torsion bars in the a-arm.
The bushings absolutely should be replaced and could very well be the problem allowing them to rub and, possibly fail. I'd be surprised if normal pitting alone with street use would cause the t-bar to fail.
Tony G
2000 Boxster S
Old 05-16-2011, 12:41 PM
RETIRED
Joe Bob's Avatar
My bad...prolly just a lot of sparks, then a fire.....
Old 05-16-2011, 12:43 PM
