915 shifter
How can you tell if your 915 shifter has a factory installed short shift kit in it?
Thanks,
Tom B.
Old 04-26-2011, 12:02 PM
Peter Zimmermann's Avatar
If you have an option code sticker on the underside of your front trunk lid you can check that. If your car is an '85, your shifter will be 10% shorter than all years from '73-84 (1972s used a different shift tower). If your car is an '86 it could have the same set-up that '85 models were fitted with, but it could have the optional 20% shorter unit (10% shorter than stock '85/86 models, 20% shorter than all other 915s) referred to by most as the super-short shifter. So, if your car is an '86 there is a chance that a factory SSS was installed (check your option codes for #243), and it's the only year that a "super short shifter" was offered.
Keep the Shiny Side UP!
Pete Z.
Old 04-26-2011, 01:20 PM
One easy way is to see if the top of the shift lever has a collar welded to provide a stop for a leather shift boot.
The definitive method is to observe the shape of the "shift fork", the rectangular metal box that contains the shift lever. The factory short shifter uses a fork with a curved top edge (see photo) and the pivot pin hole is above the vertical center line of the fork . The standard shifter has a flat top surface as does the '86 semi short shifter. However the pivot pin hole in the '86 unit is slightly above center as shown.
Factory Short Shifter parts:
'86 Semi Short shifter "fork";
Sherwood
Old 04-26-2011, 02:03 PM
Thanks for the info .
No build codes to refer to as this shifter is in my 914-6 race car., but the pictorials helped alot.
Tom B.
Old 04-27-2011, 11:55 AM
