Key Broken inside ignition lock
My key broke off inside the ignition lock. I tried getting the broken piece out with small screw drivers and tweezers but no luck. I've taken the ignition and steering lock out and am now starting and turning off the car with a screw driver. Is there a way to take the tumbler apart and get the key out? If not, what are my options? I would rather not spend the $670 on a new lock-ignition set if I don't have to.
Old 04-26-2011, 12:35 PM
try using two sharp picks, like big sewing needles. one top, one bottom and try to lever it out enough to grab.
206 637 4071
Old 04-26-2011, 01:14 PM
gtc gtc is offline
abides.
gtc's Avatar
Been there done that... if you can't get the key out, just bring the thing to a good locksmith and you should be going again for $40 tops.
Graham
1984 Carrera Targa
Old 04-26-2011, 05:03 PM
pete3799's Avatar
Do as JW says.
Worked for me.
Pete
79 911SC RoW
Old 04-26-2011, 05:17 PM
RETIRED
Joe Bob's Avatar
Keys don't break off all at once.....how long was there a crack?
C'mon give it up.....
If you have AAA they will actually cover the extraction and key replacment. They WILL put a letter in your permanent file.....
2012 ML350 3.0 Turbo Diesel
Old 04-26-2011, 07:47 PM
kramer747's Avatar
speaking of keys - i wanted to get a spare made. No luck at hardware stores. Dealership wante $85. Apparently you give them your vin and they order a new key from Stuttgart.
Old 04-26-2011, 08:15 PM
John W
Spare key - pick up a blank from our host and go to a good locksmith not a home improvement store. Mine worked great.
John
89 3.2 Targa 123k miles
Old 04-26-2011, 08:25 PM
kramer747's Avatar
link please Wayne?
Old 04-26-2011, 08:26 PM
jdbunda's Avatar
Porsche 911 Miscellaneous - Page 11
Old 04-26-2011, 09:26 PM
kramer747's Avatar
I don't see them for 1983
Old 04-27-2011, 06:28 AM
Thank you
Greatly appreciate the advice. I will be going to a locksmith . . .
Old 04-27-2011, 01:38 PM
kramer747's Avatar
and close that trunk!
Old 05-01-2011, 10:02 PM
kramer747's Avatar
I ended up getting a copy made at a locksmith - $4.50!!
Old 05-01-2011, 10:04 PM
Same thing happened to me today!
My one and only key has been getting progressively worse (worn and cracked). Last week I ordered a replacement blank key from our host, but it has yet to arrive. I have been limiting my use of the car, but today took her out with a fellow Porsche 911 enthusiast. I mentioned to my friend that my key is operating on borrowed and time. Then sure enough, I go to turn the key and it snaps off in the ignition!
Lucky for me, I happened to be stranded out front of the top Porsche mechanic in the country who has worked in the past for RUF. He helped me pull the ignition switch and setup temporary operations with just a phillips head screwdriver.
When I got home I was able to work the broken key out by gently tapping the ignition switch onto a block of wood. Thereafter a set of small needle nose pliers pulled the shard completely free.
Now I guess it's time to call the Porsche dealer and order a new key...
Old 09-10-2011, 10:17 AM
