Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Help testing warm control pressure
In the next few days, I'll be testing system and control pressures in my car.
My question is, is there a way to keep the WUR heating element switched on without the pump working all the time ? some shunt ?
Old 04-26-2011, 01:27 PM
I always pull the plug on the WUR giving me cold pressure then plug it in for the time for warm up.
Bruce
Old 04-26-2011, 01:54 PM
I may be wrong, but I would think you could just pull out the fuel pump relay...should be the red one under the hood.
1980 911sc Irish Green
Old 04-26-2011, 05:27 PM
A 74 doesn't have a fuel pump relay.
On my 75, there is a 2 wire connection to the fuel pump in the left front of the engine compartment, directly below the fuel filter.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 04-26-2011, 06:16 PM
FP and WUR........
prebordao,
For the '74 & '75 CIS, the WUR's heating element won't get energized until the alternator starts to run or operate. To answer your question, you could make the WUR's heating element ON with the FP shut off but why? How could you test the fuel pressures with the FP shut off? Would you like to share with us your objectives? Thanks.
Tony
Old 04-26-2011, 07:36 PM
Banned
To clarify, I want to test the pressure with the pump on !
My idea was to keep it off just while the element is heating... but there's probably no need for that and this way I can see if the pressure starts changing or not.
Old 04-27-2011, 05:57 AM
I had the same thoughts as Tony--it can be done but why? You can do your system pressure and cold pressure tests with the engine not running and it only takes a few minutes.
If you want to check just the wur heating element, you can pull the wur relay (round black) in the engine compartment electrical panel and jump terminal 30 (red/black wire) to terminal 87 (red/white wire). Then, turn on the ignition--fuel pump will run and wur will begin to heat up. Or, you can just start the engine and monitor the pressure change as it is running. (See this diagram for wur relay: http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1973_CIS_add.jpg
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-27-2011, 08:01 AM
Banned
This is simpler than I thought. I'll hook the gauge, test cold pressure and turn on engine and let it run...
Old 04-27-2011, 09:31 AM
Banned
I had problems figuring what fittings to use from the ones that came with the gauge...
I admit I was in a bit of a hurry, but I couldn't find a combination that allowed me to insert the gauge between the FD and the 2 lines going to the WUR and the throttle valve. I ended up inserting it between those 2 lines, instead of just by the FD. Do you understand ?
I suppose that's the reason I got 3 bars of system pressure instead of 4-5...
we'll have to look again at those fitttings.
Old 04-28-2011, 03:39 AM
Banned
bump
Old 04-28-2011, 05:54 AM
Location: behind the redwood curtain, (humboldt county) california
The 74 has a throttle position pressure regulator. It is plumbed in parallel with the wur and is also adjustable.
If i understand it correctly, (which is very unlikely), it richens, (allows controll pressure to lower), just off of idle, as well as at full throttle. So, if it is adjusted to come in too soon,it may provide a false reading as you test the wur.
When i picked up my dad's car, the throttle position regulator was disconnected and the car runs reasonably well??
I need to do some more research on this fine bit of 73.5-74 only CIS magic.
HTH,
chris
Old 04-28-2011, 07:16 AM
On the early CIS, 73.5 and 74, you will need to connect the gauge set between the fuel distributor and the throttle positioner. It sounds as if you put it between the positioner and the wur. You are correct on your reasoning, you will get a low reading on the system pressure.
L.J.
Old 04-28-2011, 07:23 AM
Banned
Ossiblue,
Have you used the gauge kit that pelican sells ? If so, do you remember the fittings used ?
Old 04-28-2011, 07:31 AM
Dave Kost's Avatar
1973.5 CIS Pressure test gauge hook up
Where does the gauge go?
Between the FD and WUR?
Dave K
Old 06-16-2011, 11:19 AM
On a 73.5, the gauge goes between the FD port and the throttle positioner and WUR. In other words, be sure the line going to the positioner and WUR are on the valved side of the gauge.
L.J.
Old 06-16-2011, 05:20 PM
Dave Kost's Avatar
Thanks....sorry for the double post.
Dave K
Old 06-16-2011, 06:41 PM
