Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Valve
According to our host these two parts are NLA.
Any thoughts on equivalent(s)? Thanks in advance, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Fleabit peanut monkey
Probably a one way check valve.
Help/Universal One-Way Vacuum Check Valve (47149) | Check Valve. Universal Type | AutoZone.com If you go that route you will need to change out the hoses to fit. Try calling Stoddard Porsche. They have a mail order department that specializes in older Porsches. I can't find the part on their website but they have found some unlisted parts for me. Tell them you are a PCA member for a discount. |
RETIRED
Is that the decel valve? If so, not a required item except for smog. You can try Parts Heaven or call the BAR and they will give you a list of shops that specialize in smog stuff.
The alternative is blocking the line and disableing it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Part 34 you can make it up with one hose inside another with some avation permatex for a seal.
Is this what we used to call a breather valve? Thanks again.
RETIRED
The decel valve slows the throttle closing on decel and limitting excess hydrocarbons. Blipping the throttle is a bad thing in CA.....
They don't test its effectiveness at smog check time but they look for it.
muck-raker
Gerry,
Call your local Porsche dealer with the part numbers, they will be able to get them for you. FYI, I have an extra "sleeve" (part #34 on your chart) that I'll ship to you gratis. I'm sure you'll pay it forward in spades. Just PM me to let me know if you want it.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Member 911 Anonymous
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
