c2kid's Avatar
sc cam timing query
aloha, i'm just finishing up an ovwehaul on a 79 big valve 3.0 engine and am having an issue with cam timing. i have done several other engines and have never had this issue. i time the cams (08, sc cams) to 1.55 lift at z1 with the chain tightly tensioned and tighten the camshaft locknut. leaving the dial indicater on i test the timing after tightening the nut. still spot on. however, when i replace the tensioners the cam timing advances about .35 to around 2.0 whats up??? (the chains are new and the gears don't have any visable wear) any ideas???? cheers, geoff
Old 04-27-2011, 10:21 AM
What do you mean "replace the tensioner?"
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-27-2011, 10:56 AM
SP2 SP2 is online now
SP2's Avatar
Maybe you need to prime the oil feed tensioners first before checking.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 04-27-2011, 11:32 AM
SP2's Avatar
Here is how I did my 81SC in 2007 with photos. Hope it helps.
Seattle Engine Drop III: reassembly - Rennlist Discussion Forums
James
1981 911SC Wine Red
Old 04-27-2011, 11:36 AM
kodioneill's Avatar
That is a must!
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-27-2011, 01:07 PM
c2kid's Avatar
aloha all, by replace the tensioners, i mean i use a c clamp to tighten the left one and a factory tool clone to tighten the right chain and after adjustment put the tensioners back in. these are the original tensioners and not updated oil line fed. i'm wondering if maybe they don't have enough spring in them. i did soak them but maybe they're getting air in them when i compress them into the holder tool as i've been using a horizontal vise?
Old 04-27-2011, 03:58 PM
SP2's Avatar
Maybe just prime them anyway so there is no air. Just submerge in oil and move the plunger in and out so there is no bubbles. Then install them both. Then reset the timing without the supplemental tension. That's my guess. (It's good that you rechecked the timing after you put the tensioners back in.) Btw, is that a stock Sc can? If it's an upgraded 964 can, 1.85mm is wrong.
Old 04-27-2011, 05:00 PM
Actually the timing is what it is regardless of the the tension type. When the engine is running and the cams are being pulled by the chain the measurement you are getting with the tight chain will return. The chain will lose any slack that is being shown using the factory tensioners when it is running. Do not reset the cam timing using the factory tensioners. Set it using the method you have already used and put it back together.
Lindy
Tell it like it is or don't tell it at all.
Old 04-27-2011, 05:11 PM
c2kid's Avatar
hmmmm
i think i'm leaning towards lindy's view. the chain will tighten with the engine running (thus correcting the timing) sometimes i think too much. thanks to all, gb
Old 04-27-2011, 06:16 PM
The chain will stretch with heat and the valve spec will become a lower value.
Bruce
Old 04-27-2011, 07:02 PM
If you can push in the tensioners by hand they are toast. Buy new ones or rebuild yours. The non oil fed tensioners are hydralic in the sense that they have oil sealed inside them with o-rings. It should take a strong c-clamp or bench vise to compress them. Do it slowly. Insert pins to hold them down and when installed pull the pins. This would be a good time to install the Carrera tensioners(oil fed). I can not stress enough not to install the tensioners if they are easily compressed. You can blow the motor. Good luck.
69 911 2.3Ez
85 928S
Old 04-28-2011, 06:54 AM
Under the radar
Trackrash's Avatar
+1
The old style tensioners need to be rebuilt every 50K miles or so. Think about how old the oil is in those old tensioners. It's also a good idea to install "chain savers" on the tensioners. The old style tensioners work just fine as long as you don't expect them to last for ever.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-28-2011, 09:01 AM
