Wingnut
Can't Keep it Running
Newbie here. I've just started experiencing an issue with my '78SC, 60k miles, an all original beauty. It started while coming to a stop the engine died. Restarted pretty quickly, but then started happening more often. Now I can't keep it running. The fuel pump had been making itself noticed by buzzing, so I replaced it thinking (hoping) it was getting ready to give up and causing the problem. The replacement fuel pump sure is quiet, but I'm still having the same issues. Any ideas? Any help is greatly appreciated.
Member 911 Anonymous
Have you checked the fuel pressure or replaced fuel filter ( if you have one ). Maybe injectors are clogged as well. Throw some BG 44K and after a new tank replace the fuel filter???
BTW, She is a beauty. Welcome aboard. SC owners can better chime in.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Is this happening only at idle or at any RPM? If the engine dies at idle only and the issue has gotten progressivly worse with time I would look at idle mixture (a.k.a vacuum leaks). Check for leaks in the intake system. For more advanced tests you need special tools to check the control pressure of the CIS system.
If the engine dies at all RPM when hot but restarts easily you could have a failing CDI ignition box. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
the mixture may have changed for some reason. either air leaks, making it lean, or control pressures, making it rich (or lean).
when you restart it, how does it idle? any popping? does it surge?
i just went thru the same symptom, same prob last week.
turned out to be a combo if dme prob and old gas. replaced dme and cleaned the gas tank. hope this helps.
ed ed's flyfishing outfit bozeman, mt '92 964 C4 chevy p/u |
try raising the idle speed (need flattip screwdriver) a little and see if that helps.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
CIS not Motronic........
Ed, Maybe you did not notice it but the guy has a CIS engine not a Motronic like yours. The '78 SC don't even have ECU and OXS in the system. Tony |
tx........it's not e z being uneducated.
Wingnut
Thanks for all the responses, I have replaced the fuel filter, no luck. When I can get it started it will idle relatively well for a short period (10 ~ 15 secs) then it stalls. If I leave it sit for a minute, then crank it for a bit it will restart, but then stalls again pretty quickly.
I promised my wife when I bought it that I wouldn't need to keep my mechanic on retainer, let's hope we can figure it out! |
CIS troubleshooting.......
TBone, Your problem could be simply an out of spec cold control fuel pressure which could be easily adjusted. So investing into a $80-$100 fuel pressure gauge kit would probably the best prudent tool purchase you'll do when owing a car like this. Get some reference maintenance manuals like Bentley, Wayne's 101 book, etc. and you could start tinkering your car's maintenance work. Tony |
