grahamkissack's Avatar
where does this ground cable connect?
My 1980 SC runs great and during a third brake light install I discovered this disconnected braided ground cable behind the rear fuse panel....nowhere obvious jumps out?
Thanks in advance. Graham
"Penelope" 1980 SC Targa in Grand Prix White
Old 04-30-2011, 11:26 AM
Grady Clay's Avatar
Graham,
Where is the ground coming from?
Someplace back here (green arrow), there is a ground stud on the inner fender where this ground can go (unless it is coming from there).
If it is coming from that ground, I suspect it attaches to the aluminum electric panel.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-30-2011, 11:38 AM
Thanks Grady...yes it comes from back there where you have the green arrow. I notice the aluminum panel floats on rubber insulators so I wasn't sure if it was grounded or not? Perhaps it attaches at the rubber gromet near the top?
Old 04-30-2011, 11:42 AM
E Sully's Avatar
You can see it here on the lower right of the console. Since the console is insulated by the rubber mounts, it needs this ground lead to the chassis.
Ed
1973.5 T
Old 04-30-2011, 12:49 PM
Senior Advisor
James Brown's Avatar
Yes it is a ground to ground or a bonding wire. Ed's pic is correct.
08 Cayenne Turbo
Old 04-30-2011, 02:02 PM
Thanks all. I'll connect it tomorrow.
Old 04-30-2011, 07:47 PM
Mine was trapped between the alum. plate and the rubber mount.Insert bolt into panel, slip the ground wire over the bolt and fasten assembly to mount. HTH Jim
Old 05-01-2011, 03:13 PM
Almost Banned Once
sc_rufctr's Avatar
Mine was just sitting behind the panel not attached to anything when I bought the car. This is how it looks now after my MSD install.
- Peter
Old 05-01-2011, 03:31 PM
