Front Shock,what type best
Hi,
I planing to install new front shock on my 67 911,what brand is the best?
Thanks.
Micke
Old 04-29-2011, 02:08 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh my. Well what type of use? Street/ Track/AX/DE, a mix of all? Do you have any other upgrades or OEM?
'85 Carrera Targa
PCA/POC
Old 04-29-2011, 05:20 PM
Under the radar
Trackrash's Avatar
What do you have in there now?
Are you planning on an upgrade or update? If so there are lots of options.
Koni's would be the way to go for a 67 that you want to keep fairly original.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-29-2011, 08:05 PM
Hi,
I think it is bilstien green on, driving street and some time track,planing to uppgrade
white turbo steering kit and a elephant breach in the front, my car runns very good
but I like to have a bit of upgrade on the road performing,so please come white ideas
I like to keep it close to the original. 67 S .
Micke
p.s Maby I drive to much in my 930 88, but I like the 67 more and I think with
some upgrades it will be the favorite.
Old 04-30-2011, 12:01 PM
Under the radar
Trackrash's Avatar
If it was me, I would put Koni struts with Koni sport inserts. That's what I did on my 71. Newer style stronger ball joint on '72 and up struts, and externally adjustable shocks.
Only problem is Koni struts have 3.5" caliper spacing, so you would have to also upgrade to alloy S calipers and 20mm thick rotors which is what the S had.
Or you could go with Bilstein struts off a 74 or newer 911. More money, not adjustable, and you still have to upgrade your brakes and ball joints. But if you like Bilsteins...
Or what a lot of guys do is get the newer (SC) Boge struts. With those you can choose what insert you want and Boge struts are not to expensive. You still have to upgrade your brakes and ball joints.
Gordon
Old 04-30-2011, 07:57 PM
