ITG Filter / Charcoal Canister Hook up
I been loaned a pair of ITG filters for my 72T, on a sale or return basis. Been looking through the posts about the breather hook up etc but can not find any information about where (and if) I should connect the charcoal canister.
So how have you guys done it? |
One option is to drill a hole in the baseplate (it's aluminum), then use a grommet, hose connector and hose for PCV systems; sourced from your LAPS. May need an adapter to connect the different hose dimensions. To avoid burping oil into the intake, I suggest you install a breather tank to vent crankcase>oil tank blowby pressure, then connect a hose from the breather tank to each ITG baseplate. The fuel tank breather hose could be routed directly to the breather tank as well. Sherwood |
Sherwood, thanks for the reply, and no it doesnt include the hole(s) I'll have to drill!! Just trying to work this out before I start messing and modifying.
So basically what you are saying is gas vent into catch tank, and the oil vent. Then two hoses out (like your set up) into each of the filters? When drilling the base plate do I go through the filter material? They are like these ones BTW; http://www.rennsportclassics.eu/product.php?id=54 Thanks in advance. Last edited by rads; 05-08-2011 at 09:14 AM.. |
Oil tank/fuel vapor hoses > to breather tank (aftermarket or equivalent); Outlet from breather tank; two hoses, one each to the base plate of each air filter housing. Many owners vent to atmosphere, but let's reburn it in the engine. Holes through foam: No. Create appropriate inlet hole in each al. base plate. Hope this helps. Sherwood |
These are cool as hell and if you get it straightened out, please post pics.
72 911 Although it is done at the moment, it will never be finished. |
just get a oil catch can /breather from Summit or Jegs and call it a day. No need to vent into your intake.
I have had no issues with fumes, etc with this set up... Here is the one I have... http://www.summitracing.com/parts/MOR-85473/
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-08-2011 at 06:20 PM.. |
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 05-09-2011 at 03:18 AM.. |
Yes. My car is a street car. Ill take a few pics..
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
AutoBahned
the oil catch can /breather from Summit or Jegs are not the best -- Sherwood or Grady posted the things you really want in one
it will work better if you vent into your intake, tho that is not absolutely necessary |
AutoBahned
note the large hose and hole for the oil vapor to go thru - that's just one "good idea"
just search on the key words and it should pop up - I don't have a link |
