Carrera Cowl Vent Block Off?
What are people doing with no HVAC and fan box removed doing to block off the vent (mostly for water) I was thinking of cobbling up something using the existing fan box and the drain tube but - probably rather just have it blocked off so no water can get in.
I could have sworn someone made one - can't find it now...
Jeff |
i am also in the same dilemma..i thought that someone made a piece to replace all that other stuff! need help too!!!
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp |
porsher
Make a blanking plate out of 1/8" aluminum sheet. Just trace around the outside of the grill, cut and peen gently with a hammer to shape.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Member 911 Anonymous
So you guys are not using the FRESH AIR at all?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
one of the aftermarket places does make (or used to make) a block off plate. I think it has a duct to bring fresh air in, but can be easily closed off in case of rain (like it flips to 2 different positions). I can't remember the brand but IIRC it was pretty expensive, which is why most people make their own.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
porsher
I removed the blanking plate and made an aluminum plenum instead. This supplies fresh air to the driver.
yeah, i made one for my other porsche but was going to take the easy way and buy one if not to expensive. and, yes i placed ducts on the box such that fresh air was ducted into the cabin.
