80 911 SC, Orem, Ut
RSWiser's Avatar
9mm Triple Square
I am trying to change the Door Latch on my 911 SC. I bought a set of Triple Square 12 pt. bits. Set came with 6mm, 8mm, 10mm and 12mm.
Well those don't fit. It is a 9 mm.
Can anyone give me a good source for a 9mm 12pt. Triple Square bit.
I have check all over the internet and all of the local hardware and auto parts stores. No 9m.
I found one set at Amazon but it is a set of 9 pieces. Only need the 9mm.
Don't really want to pay $36 plus shipping for one little bit.
Rob
1980 911 SC
Old 05-10-2011, 02:33 AM
wouldn't be 9mm. the "striker" on the b pillar would be 8mm. never seen any 12 point fasteners on the latch in the door....yet.
206 637 4071
Old 05-10-2011, 06:16 AM
proffighter's Avatar
WRONG, never seen Hex heree (except my car )
You mean P/N 999 219 008 00 M8x40 Countersink screw
More here:
What bit is used for adjusting door strike plate
Roland
930 Turbo '81 Too many modifications to list
Old 05-10-2011, 07:25 AM
Wash. State
nesslar's Avatar
"Well those don't fit. It is a 9 mm."
That's beyond me, and surprising. Could they have been replaced somehow with non-OEM??
Edit: Just checked, 8mm triple-square for mine....I am assuming you do mean the striker plate on the body...
Edit: Odd...your's isn't "stripped out" is it? I reckon that would be pretty obvious, but it would explain why 8mm won't bite...
Old 05-10-2011, 07:41 AM
80 911 SC, Orem, Ut
RSWiser's Avatar
One bolt I was able to get with the 8mm the fit was loose but it worked. The other bolt the fit is to loose and would strip if I tried.
It is the striker plate I am removing. I could use a remover tool and replace it. It does not look stripped but the 8mm will not fit.
Old 05-10-2011, 08:25 AM
Wash. State
nesslar's Avatar
You might try heating the heck out of the 8mm bit; maybe enough expansion will do the trick.
Old 05-10-2011, 08:31 AM
