Send a message via AIM to mercury26 Send a message via MSN to mercury26 Send a message via Yahoo to mercury26
915 Shift Coupler Leak???
I recently purchased a 1982 911SC and finding all kinds of wonderful things. I was doing some work on the car last night and notice some transmission fluid leakage coming off the shift coupler panel. Does anyone know where this might be coming from? Are their some seals behind the panel that might be leaking? I am just trying to get a sense of where the leak might be coming from.
Thanks,
Chuck
Old 05-10-2011, 11:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It must be your front seal that is leaking, hell when TRE placed my SS kit, they showed me the dust cover was full of trans fluid.
Post a pic and we can be certain.
'85 Carrera Targa
PCA/POC
Old 05-10-2011, 11:27 PM
Oh Haha's Avatar
+1 on the shift rod seal. It CAN be done without gearbox removal.
Pacific Blue
Wayne
Old 05-11-2011, 03:53 AM
Almost Banned Once
sc_rufctr's Avatar
It can be but it's difficult.
A few years ago mine started leaking. Not a lot but enough to be worrying.
So as a temporary fix I cut an old bicycle tube to the right size and slid that over the shifter rod and alloy housing.
Taped and zip tied in in place and drove it LEAK FREE for about 3 years...
(Make sure it's a bit longer than it has to be so it doesn't bind and interfere with shifting.)
I finally fixed the problem properly after I had to replace my gearbox because the differential had failed.
- Peter
Old 05-11-2011, 09:32 AM
AutoBahned
RWebb's Avatar
I'd say it is tricky, rather than it's difficult...
you'll want a couple of the seals (in case you mess up one of them), some good light sources & a collection of pick tools
pick out the old one; check for burrs with your finger; bandage finger; deburr & push in the new seal
Old 05-11-2011, 04:20 PM
AutoBahned
RWebb's Avatar
there is a thread on this somewhere on here
Old 05-11-2011, 04:22 PM
Peter Zimmermann's Avatar
Or cut the rubber boot off so the trans oil will leak onto the ground, and not into the tunnel of your car.
Keep the Shiny Side UP!
Pete Z.
Old 05-11-2011, 06:07 PM
If the shaft is scratched or damaged, replacing the oil seal won't help. Shift the transmission into 2nd, 4th or reverse, which will pull the shaft foward, and inspect it closely.
Jon B.
Vista, CA
Old 05-11-2011, 06:34 PM
I once had a car with a bent shift rod. That can happen when removing the engine if not done correctly. Anyway, it would leak if left in first gear because the shift rod is pushed into the engine more than 2nd gear or reverse. With the rod pushed in furthur the bend makes the rod offset more and causes the seal to leak. Most likely you just need to put in a new seal, but check to make sure the shaft isn't bent.
-Andy
Old 05-12-2011, 10:14 PM
-Andy
Did the bent shift rob require pulling the transmission? Or is the external rod from the shifter in the car to the transmission?
Thanks,
Chuck
Old 05-12-2011, 10:26 PM
