Central locking question
I have an 86 3.2 Carrera coupe, the locking button lights brightly when a door is locked but pushing the button will not lock or unlock the doors. The drivers side lock will lock or unlock both doors. Where should I start to trouble shoot? I would like to install key less lock/unlock but I think the factory system needs to work to make an easy install.
Thanks,
Bernie
Old 05-11-2011, 07:11 PM
Recreational User
porschenut's Avatar
Both locking mechanisms in the doors work, and the button in the console appears to work, so that leaves....the control module, the most expensive part. Although, I suppose it could also be a faulty relay. That's cheap and easy to replace so you might try that first. It could also be that the pushbutton light works but it isn't sending a signal to the control module.
Verify that both doors lock and unlock with the key on both sides. Verify that both doors lock/unlock with the round knobs on the door panels.
Old 05-11-2011, 07:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
How is your Fog Light Switch at the Dash, LOose or Tight?
When I replaced mine, I noticed one of the wires effected my central locking system switch/light. It was loose and did not activate the switch but it did light when I pulled the Fog Light Switch. Doubled checked the contacts and all is good now.
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 07:31 PM
