Phrog's Avatar
Fuel Overflow Valve Question
Can anyone recommend a replacement (Upgrade) fuel overflow valve for a 1971 E with original MFI. This is the valve located on the fuel filter console. Ideally one with a threaded discharge so a 6AN line could be attached directly or with an adapter. It would be the line that the return hose attaches to in diagram below.
Thanks,
Kevin
Kevin
84 911 Carrera
71 911E Vintage Race Car
25 Ford Explorer ST
20 Subaru Crosstrek
Old 05-20-2011, 08:09 PM
Bump - also need one
Old 10-10-2016, 12:21 PM
The part is available from pelican under p/n 901-110-915-01-OEM. I bought one and it works fine. I don't know of any aftermarket direct-replacement options with different fittings. I looked into using an adjustable fuel pressure regulator but after considering all the adapters and plumbing I'd need to hook one up I decided to go stock replacement.
If there is a small adjustable regulator that can be installed as a direct replacement for the fuel overflow valve I'd be interested. I don't think there is.
Edit: I have 11.8 psi at the fuel return line with the new overflow valve
Old 10-10-2016, 01:35 PM
