Fuel Overflow Valve Question
Can anyone recommend a replacement (Upgrade) fuel overflow valve for a 1971 E with original MFI. This is the valve located on the fuel filter console. Ideally one with a threaded discharge so a 6AN line could be attached directly or with an adapter. It would be the line that the return hose attaches to in diagram below.
![]() Thanks, Kevin
Kevin 84 911 Carrera 71 911E Vintage Race Car 25 Ford Explorer ST 20 Subaru Crosstrek |
Bump - also need one
The part is available from pelican under p/n 901-110-915-01-OEM. I bought one and it works fine. I don't know of any aftermarket direct-replacement options with different fittings. I looked into using an adjustable fuel pressure regulator but after considering all the adapters and plumbing I'd need to hook one up I decided to go stock replacement.
If there is a small adjustable regulator that can be installed as a direct replacement for the fuel overflow valve I'd be interested. I don't think there is. Edit: I have 11.8 psi at the fuel return line with the new overflow valve Last edited by 422flat6; 10-10-2016 at 01:46 PM.. |
