A post on Rennlist suggests to use the four jacking pads on the tub portion under a Porsche to lift it rather than the normal location on the torsion bars. I've never seen these or heard anyone else speak of them before this. Is this legit or am I misreading what he's saying?
http://forums.rennlist.com/scripts/rennforums/ultimatebb.cgi?ubb=get_topic&f=1&t=002229 |
GAFB
They're there- if you've got an '86 or later.
Several BMWs |
Oh, that explains it. I have a 79. thanks. I'm SOL again.
i've got an '86 but no pads
Rich ![]() '86 coupe "there you are" |
Irrationally exuberant
Chris '86 911 (with jack pads) |
Someone stole my jackpads!!!! I looked and there gone!
86Carrera 01 saab Viggen 88 Lebaron(winter Porsche) 41'UTB http://doofdog.homestead.com |
ok, first the local dealer can't find any record of my car, next i find out its got a US engine, NOW i've got no jack pads
is this cause for concern?? what exactly are these jack pads?? you can't remove them can you??
They are welded to the car. I was joking about them being removable. -Chris |
thanks chris
my '86 doesn't have them though i'm a bit worried - its put me right off my mac d's
Front and rear jack pads on an 89 coupe. These are meant for a garage lift to pick the car up as one unit. It you jack up one of these, you will end up deforming the metal. I would still stick to the torsion bar tubes, front and rear, and center of engine, for jacking up the car. These are good places to put added supports for safety and perhaps to get one wheel off the ground. |
89911
thanks, i definitely do not have those. was the changover year '86? does anyone know??
I have seen heavy plates welded to platform in front of rear wheels that I believe came from factory stock. I would like to install them on my '77 if available.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
You can use blocks of 2x4 to distribute any stress over a larger area. Size the wood as your conscience dictatates, it mostly prevents marring of the under coat.
KAHUNA...what I presently use is 3x3x8 hard rubber pads sold by Snap-on with their mid rise lift. Works great.
Years ago I bought a 6" silicon pad that fits over the saddle of my floor jack(as such it prevents any shifting of the load, which is a drawback of wooden blocks). Unfortunately it's falling apart, and even more unfortunately I haven't seen them offered for sale anywhere recently. Industrial polyureathane sheeting also works but is relatively hard to come by.
Schleprock
1. As 89911 said, if you jack on these you can smash 'em. 2. If you jack on these, HOW ARE YOU GOING TO PUT A JACK STAND THERE? THE FLOOR JACK IS IN THE WAY!!!! I find the jack ports and the suspension connection points to be just fine for getting the car in the air. I put the jack stands at these feet thingys because that's their intended purpose, in my opinion. To each his own.
Kevin L '86 Carrera "Larry" |
I agree with the comments to use the standard torsion tube and a-frame locations for floor jacks. I was interested in these body locations since I'm starting to look for a good garage lift in anticipation of one day buying another Porsche. I'd also like to get a lift where the wheels and suspension can hang freely so I can more easily work on the car.
Evidently, the shops do support the earlier cars on lifts using points on the tub or frame without any damage. I've seen them do it many times during tire removal but I honestly was focusing on other things at the time. I'm not sure if any damage could occur if my 79SC is supported long term from the points just behind and in front of the wheels. |
Autob...the points you mention is what I use all the time. It is a good strong area to my understanding. I've had the 911 on these points for months, no problem,,,I hope. I also use a Snap-on mid-rise lift. It's small, portable, supports 6,000 lbs., and low when in down position. A euro ride height 911 can drive on/over it. Got it used for $1400 about 6 years ago. I over-paid because it was 1 1/2 years old. Should go for $1000 today. New 4 years ago was $2,800 + shipping + tax. Snap-On has a seperate brocheure on it. Mid-rise = 37 inches without 3 in rubber pads
As far as the jack point "feet" go, I jack on them all the time without damage but generally I use them for the jackstands. -Chris |
One interesting thing I found out about the dealership in Kansas City is that they do not work on any Porsches older than 1980. Since I use an independent mechanic (when I don't do the work myself), I had not run into this issue. I wonder is this a local thing or are other dealerships across the country also limiting the cars they will work on. I'm surprised Porsche allows one of their dealers not to support a product they sold; regardless of the age. 79SC |
