Mo money = mo parts
Swing Arm Locking Bolt - What the heck wrench did you use?
I purchased a 36mm flat spanner wrench for the height adjusting bolt on the swing arm, but am having trouble with the locking bolt. The bolt head appears to be 24mm, same as the nut, but all the 24mm wrenches seem to be too thick. I can't find a 24mm flat spanner.
How did you hold the locking bolt in place to get the nut on or off? I think it requires 87 lbs of torque.
thanks.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-24-2011, 10:08 AM
70S Targa Guy's Avatar
Location: A scenic and exhilarating drive along the Delaware River just one hour from Philadelphia, PA
You should have purchased this:Pelican Parts - Product Information: PWE-2436RHW
If you plan to visit the Phila area you can borrow mine.
Old 05-24-2011, 10:33 AM
Mo money = mo parts
Dah. It was in my project list cart already. Thanks for the offer to borrow, but I will just purchase one today.
Greg
Old 05-24-2011, 10:43 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Or Grind a cheap one down to slide it in.
Or loosen the 4 end cap nuts out to about an 1/2", slide off the end caps, slide a standard 24MM in.
Torque is 61lbs for the eccentric bolt and 177lbs for the lock nut
'85 Carrera Targa
PCA/POC
Old 05-24-2011, 10:56 AM
cycling has-been
bkreigsr's Avatar
Originally Posted by 70S Targa Guy View Post
double dah - I wish I had seen that before I scoured fleabay for a 36 mm headset wrench and a Stahl 24mm open end. Neither one of them will work without a little massaging.
Bill K
Old 05-24-2011, 11:19 AM
Friend of Warren
Or go to your local bicycle shop. They will have the thin 24mm wrench you need.
Kurt V
Old 05-24-2011, 11:22 AM
Hi Draco,
Are you sure about the 61 LBS torque for the Height adjustment eccentric bolt? I don't have a Bentley. If so, I am going to have to ammend my notes (and check the torque for that bolt on my car) that I got on this forum during my searches. For some reason I thought both the Lock Bolt and Height Adjustment Bolts were both in the 180 LBS range.
Rearward, I think the toe eccentric bolt is 43LBS, Camber is 36LBS and the 2 Spring plate to swing arm bolts are 65LBS.
Old 05-24-2011, 12:23 PM
DRACO A5OG's Avatar
Hi Draco,
Per bentley, Yes.
Oh crap, if you did that to the eccentric, height bolt, you could have snapped it on your other Thread
177lbs only on one of the lock nut each side.
Toe and Camber is 61bls also
The two rear Lock nut (spring plate to swing arm bolts) are 87lbs.
Only the 4 END CAP bolts are 34lbs.
Jim
'85 Carrera Targa
PCA/POC
Old 05-24-2011, 05:42 PM
RETIRED
Joe Bob's Avatar
Park and Campy bike tools work....Lance Armstrong is outta work. Maybe you can give him a call....
2012 ML350 3.0 Turbo Diesel
Old 05-24-2011, 06:04 PM
Wash. State
nesslar's Avatar
LOL...garage sale on the horizon.....
Old 05-24-2011, 06:26 PM
Per bentley, Yes.
177lbs on one the lock nut each side
Jim
SHEEEEEEEIT! I updated my 1970 front and rear torsion bars, spring plates & bushings about a year ago with the adjustable spring plates, 22/27 TB's and Netrix bushings. My memory is not what it used to be and/or my notes are Fuched up because I just went out to the garage with my torque wrench and that fancy skinny 24/36 wrench and the torque wrench clicked at 65LB setting and did not click at 75 LBS so I guess all is good! Thanks!
Old 05-24-2011, 06:57 PM
WUNDERWAFFE
JINKATIN's Avatar
I used this one today and it worked great.
Pelican Parts - Product Information: PEL-SR2200
Charlie
1986 Carrera
Old 05-24-2011, 08:27 PM
DRACO A5OG's Avatar
Cool, bring it over this weekend
'85 Carrera Targa
PCA/POC
Old 05-24-2011, 08:54 PM
WUNDERWAFFE
JINKATIN's Avatar
You know it bro
Charlie
1986 Carrera
Old 05-24-2011, 09:04 PM
