Steering rack repairs??
My 77S is due for a full suspension rebuild. Upon inspection, I noticed that a lot of the play in the front is coming from the steering rack. Is this play adjustable and can I rebuild rack myself? There are no bad leaks, just a minor leak from the cover in the middle.
1977 911S silver/black
Old 05-24-2011, 08:42 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Leak? do you mean from the boots at the tie rods?
I replaced my U-Joints and it took out alot of slop there
'85 Carrera Targa
PCA/POC
Old 05-24-2011, 08:51 PM
steely's Avatar
+1 on the u-joints.
You can rebuild - essentially strip, clean and re-pack with grease.
Inspect the bearings and puck (thrust piece), check the lash w/o the u-joints - should yield some improvement. Check the rubber coupler too - yours may be quite old.
The leak is the grease that separated into sludge and oil.
The insides of the tie rod boots will have caught some evidence too.
Here's a good thread: Steering Rack "Rebuild" Procedure
hth
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-24-2011, 09:05 PM
I thought there was a way to do it without spending $1000 on a rebuilt rack..thanks.
Old 05-25-2011, 02:01 PM
