Slippery Slope Expert
Steam Driver's Avatar
Alternator Wiring Harness Grommet
Does anyone know the P/N of or a source for the grommet that seals the engine wiring harness where it goes through the shroud to the alternator?
I would like to remove the harness from the shroud for cleaning, etc., but I'm sure if I do this grommet will be destroyed; it's very dried and heat-hardened.
I've looked at the on-line parts diagrams and it appears that the harness grommet is shown as a separate piece but is not itemized on the parts list. Source?
Old 01-30-2014, 04:41 AM
Flojo's Avatar
I guess its 99970309240
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-30-2014, 06:07 AM
Mine was petrified like a rock. It fell to pieces when I removed it. I just measured the size of the hole and went to a local Ace Hardware. The new grommet was not identical in looks but no one can see it unless the engine is alternator is removed.
Old 01-30-2014, 07:14 AM
ROW '78 911 Targa
timmy2's Avatar
I make them for the harnesses I build.
PM me if you want me to cast one for you.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-30-2014, 09:29 AM
Thanks for the info & suggestions. I'll probably go the Ace Hardware route.
Old 01-30-2014, 11:22 AM
