Can anyone ID this engine?
![]() ![]() Is it anything of importance? Thanks..
"It looks like a Pleco.." Last edited by Plecostomus; 08-07-2011 at 09:04 AM.. |
RETIRED
Search by engine number
This site says it's an industrial engine. Stationary used for generating power for other sources, not automotive.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Do I see dual carb intakes ? I would believe these were originally single carb.
Should have this number stamped in top of case : type 616/33-1 , produced from 1963 - 1969 (1933 units) |
It's an Industrial engine and the dual port manifold shown is the industrial one that joins the ports into one, then to a single carb set up.
Mark Jung Bend, OR MFI Werks.com |
Thanks gentlemen. Would've been funny if it was found to be extremely rare!
Believe it or not this was a dune buggy engine.
"It looks like a Pleco.." Last edited by Plecostomus; 08-07-2011 at 10:04 AM.. |
RETIRED
Major money in 356 parts. Depending on your use, you'd be better off hotrodding a Type I ot IV Vw motor....
