RETIRED
Because I'm trying to figure out why I'm having such a hard time with the 16s when the 15s stripped so easily.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
getting there, and getting tired, here is the latest.
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
Well after several hours, I have conceded for today. Got them stripped, and the rash sanded out, now onto the fine sanding, compounding, and polish. Got one to a semi presentable state.....
Went thru the same process a couple of years ago. I had a neat solution to smooth out the finish. I spun them on the car! Check it out, might work for you.
New way to refinish wheels
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
Wash. State
Send 'em out....you'll be glad you did......no offense, but you could be mowing lawns in the neighborhood, much easier, less time spent, and you would probably come out ahead.....
RETIRED
It's probably still snowing up there in Newfie Hell......like here. 32F and dropping, 6-8 feet in the upper elevations.....
Make work when snow bound. I just applied for a couple of positions in Hawaii.
Wash. State
Hula dancer type positions?
...I mean, with them, of course....
LOL CLOSE TO SNOW, i survived day one, man that coating is hard , thanks Joe Bob for your sense of humour..........need that up here in the
not sure if it will work for annodization but i found that permatex gasket remover works amazing at taking off powder coating. goop it on, let it sit over night, wipe it off with a paper towel the next day.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Canucks Fan
Beer works but lay off the Screech when your working with power tools. Don't ask, it was a buddy and it was ugly.
Nice job so far, keep the pic's coming. Finn |
It has Lye in it...all the other colored easy off cans do not have lye. That is the stuff that does the trick. Rich |
RETIRED
It's the paint in the center I'm having the problem with. The anodizing came off fine. The center black paint won't budge with aircraft stripper OR lye based oven cleaner.
Bird. It's the word...
The "ingredient" for removing the anodize is lye - sodium hydroxide (NaOH) or caustic soda. When you buy the can of 'Easy Off' make sure it is the dangerous yellow version
Or otherwise some drain cleaners contain it... nasty stuff, wear gloves and eye protection and do it outside! The grey foaming scum it generates is the anodize layer coming off...
John Forcier Current: 68L 2.0 Hotrod - build underway |
When I stripped my 15s I had one wheel that was early 70s and the other that was late 70s or early 80s. The early 70s wheel was very hard to strip with aircraft stripper. It took 5 iterations to get it fully clean, the last 3 each sat overnight. Whatever they used in the early 70s was tough stuff. The later wheel stripped easy the first time. I have not stripped the 16s yet. I am guessing it will be as easy as the later wheel. Can anyone confirm?
RETIRED
I've given up on chemicals. I ordered this for my 90 degree grinder. Abrasive polishing ball. Used in marine applications. With my variable speed grinder should doo the trick. I hope....
idc1873
Poilisher
Im in the proccess of doing mine. Made this setup and trying it on my Azevs before I set on the Fuchs.
YouTube - Alloy wheel rim polisher [youtube]6LM3H_YMpfw[/youtube] Last edited by coxy; 05-31-2011 at 01:23 AM.. |
Wow !!
hi, i like these kinds of posts, i am about to take on the huge task of doing my wheels 15 X 6 on my 1973 so i am reading and trying to learn from everyone !!
thx Yves
