o2 Guage Mount
here is a autometer guage mount that i thought that i would share.
I have never had a porsche that had a clock that worked so i was not worried about cutting up the clock. The process for installing the guage was: 1) remove guage, remove ouside bezel, remove dial hands and face. 2) remove clock 3) carefully cut the back of the guage housing holding the clock in place 4) cut a slot up the side of the housing where the clock was mounted. this allows the autometer guage to slide into place. 5) connect wires and test unit. note when i was testing i thought the guage was too bight and bothered me at night so i used the headlight washer switch to power the guage. I carefully opened the washer switch so that it now acts like a toggle switch. 6) Reinstall bezel and push the guage back into place.
81 930 Turbo RoW, Slantnose, 3.5 twin plug dual MSD 6AL ignition, MSD RPM Activated boost rdelay switch set at 4400, MSD Tach Adapter, BL Wur, 18x11 (315-30-18) and 18x8 (235-35-18), Fab speed exhaust, Innovate MTX, K&N Filter Mod., NGK BPR7EIX and DPR7EIX plugs, KEP Stage II PP with Street/Race Organic Disk., Weltmiester Swaybars, Adjustable AAR Mod, AAV Delete |
Member 911 Anonymous
Nice work, I wonder if you can place a digital read out at the useless OEM speaker fade port?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
