John Brandt's Avatar
Post weird behaviour and A/c removal
I did a valve adjustment and removed my non-functioning comressor and condenser at the same time. The car is running right,(perhaps a wee bit loud) and I even had a DE weekend afterward. the Idle is higher now most of the time. What caused this? Less drag on the motor or did I botch the valve adjustment?
Old 07-16-2001, 08:57 AM
Post
the A/C freewheels when it's off, so that wouldn't be it. perhaps the engine is running more efficiently now that you've done the valves. nice work.
Old 07-16-2001, 01:52 PM
Post
The drag on the engine from the AC has got improve a bit, could explain the higher idle.
Old 07-16-2001, 05:59 PM
