Experts.. what would you do? Engine?
Hello Everyone,
I need some advice from alot of you who have been there done that. So I got my 77 targa in the garage and got it up on the stands to see what was going on. Well, as you can see the PO was apparently not a "lets do it right" kind of guy. looking at the pics, apparently smearing gasket sealant on things was the stop oil leak method of choice. Anyway, here is my question. AS far as I can tell by the numbers its got a 2.7 with a mag case. Number on the case was 901.101.102.7R. Looking at what I have seen so far and that oil is leaking from pretty much everywhere but def from between the cylinders and the case and between the head and the cam holders so it looks like this engine is coming out. Here is where I need you guys, Given the issue with head studs I have been reading about on the 2.7 engine if you already had it out, would you do the rebuild on this engine or just say the heck with it and buy a 3.0 or 3.2 or something else to put back in there? Now for the pics.. Note the sealant on the tubes..nice huh? http://forums.pelicanparts.com/uploa...1307119094.jpg http://forums.pelicanparts.com/uploa...1307119160.jpg This thing has been leaking big time for a while the trans is covered in oil. http://forums.pelicanparts.com/uploa...1307119222.jpg http://forums.pelicanparts.com/uploa...1307119262.jpg |
The problem with old leaks, is that they are likely from multiple locations.
One method is to degrease and then look for new oil paths as they occur. Another is pulling the motor and doing a top end seal with a new gasket kit. Have you down a leak down and compression check? |
Yeah, I was thinking it wouldn't hurt to spray it down with degreaser and see what happens. I have not done the compression/leak down test yet. The battery is dead and I haven't even tried to turn it over yet. I just got this car and was prepared to pull the engine if I had too.
So clean and do some testing first before making a final decision to pull. Makes sense thanks. |
I might replace a few seals, but as soon as we start talking about a rebuild the costs go up exponentially. At this point I would definately consider another motor.
You motor looks pretty much like mine did when I got it, except yours is cleaner and you already have the thermal reactor replacements. Get a pressure washer or a steam cleaner. It is faster than using a degreaser and a garden hose. Then do some basic checks and see how it runs. Drive it for a while and see where the oil stains reappear. Diagnosis is a lot more fun while driving. I had one huge oil leak (one quart per 100 miles of driving) which was not that hard to fix once I knew the source and you may have something similar. It is disheartening to see an engine covered with oil but once you have cleaned it you may find one or two small leaks which are easily fixed. My 2.7 ran like crap at first but now it is doing pretty well. Your glass may be half full!
compression?
leak down values? you should certainly go thru it after you pull the motor - you may not need a lot of expensive machining you already have the engine, so the calculus is different than if you were thinking of buying a '77 vs. a '78 in the first place |
Yep as others have said clean the motor up see where the leaks are a compression check and leakdown wont hurt to evaluate the condition of what you have. If the motor has over 60000 miles then a top end is likely needed as these motors ate the exhaust valve guide because of the heat. You can do a top end easy and inexpensive if you have skills.
Did it work ?
Might be just the way the pic was taken but the oil cooler looks unbelievably clean compared to cylinders/case. Perhaps someone already R&R'ed w/new seals? If that's the case, and compression/leakdown don't look too terrible I'd probably degrease the critter and drive it a while to see where (and how badly) it's actually leaking. You could be seeing gradual build-up of a lot of small leaks/seepage. If the sealant bothers you, pull the oil return tubes and replace w/2-piece units -- easy-peasy.
Porsche 911 & Carrera Oil Circulation - Page 1 |
Looks like red permatex oozing from the bottom of the cooler.
Bruce |
On a mag case motor, I would be more concerned about the status of your oil pressure than your compression/leakdown #'s......That's where you will have to spend real money if you have to go that route....I know a guy that spent $6K on his mag case and did all the work himself.......You can buy a good 3.0 or 3.2 for less and sell you engine as a core........
there is a nice 3.2 for sale in the classifieds right now. just saying..
Forgive me since im new to this, I see people swapping out engines in these 911s all the time, are they all just basically a direct swap or are these people doing lots of fab but not mentioning it? |
im planning on being there in my M3 (porsche is up on jack stands) but not sure. Going to a huge birthday bash tonight! :)
But, If you don't have an oil cooler, you should add one, especially living in Atlanta. That means buying additional oil lines, thermostat, etc. Have to drill a hole in the body and run a wire harness to mount your computer under the seat. If CIS to CIS, can use your fuel pump. A few wiring changes, not big deal. Your trans/clutch will work fine, might have to grind out bellhousing for a sensor depending on which year engine you go ....Your old exhaust can work, might need spaces if going from Thick flange to thin.... You should try to find an engine that includes Ignition, computer, wire harness, Induction, etc....Worth all of this if you get the right engine. G'luck. |
Wouldn't a 2r case be pre 2.7? Did you check the number on the case to verify it is a 2.7? (I could be wrong).
911lvr,
Being a fellow '77 Targa owner I was once in your position. I ran mine for about 125k miles with all the proper updates, and all original head studs. It was time for a rebuild because I was blowing oil out pretty bad. The machine work alone to do it right was alot of money. Bottom line for the same price as a proper rebuild of the 2.7 I was able to put in a completely rebuilt 3.6. Granted I was at the right place at the right time to score this 3.6. It is not cheap to properly rebuild a 2.7 due to the machine work, so if you can still drive yours around start looking for another engine. My advice is if you are thinking of a 3.2, why not just put in a 3.6? You will have a light car with a beast in the back. Tom |
What kind of things did you need to change to slap the 3.6 in there? Thanks Marc |
small update: I cleaned up the bottom of the engine, Added (yeah get this 5 qts of oil and its still not full) oil, and have the battery on the charger for now. Hopefully, later on I can turn this thing over and see what happens. Once, I get it started then i can do the compression/leak down test.
Yes. Suggest the compression test to confirm integrity of the engine. If good, then hunt down the source of the oil leak.
There are plenty of places on top of the engine that can leak oil onto the bottom of the engine; many not too expensive to repair (e.g. oil pressure/temp switches, oil breather hose/cover, valve cover, cam box oil lines, etc.). You'll have a better idea of the direction to go after performing these initial inspections. Sherwood |
Is this your first 9!!, if so you should read here about checking and topping off the oil. You don't want to over fill.
Good luck Richard |
Were I you, I would completely drain the oil and fill the correct amount. Your oil is almost certainly over full and will smoke like crazy when the oil tank fills and starts flowing oil into the air intake. How do I know? Don't ask.
So even tho when I checked the oil and it did not even register on the dipstick and after 5 qts it just hit the min mark, your saying its probably over full? and i have to ask how do you know?
Im all for changing the oil entire and will do so, I just wanted to get enough in there to see if I can get the engine to turn over and to check for where the leaks are. im not planning on driving around with it this way. |
Nothing personal brother; just trying to keep you from making the same mistake many others have. 911 is a quirky beast -- dry sump, external cooler(s) and reservoir mean dipstick is accurate only when checked under proper conditions (warm, idling, on flat & level surface). Otherwise you'll overfill and get a sticky goopy mess, and blow oil into the intake at various (and difficult to clean) locations.
Based on what I've read you haven't got her running yet, correct? If not then you really don't know how much oil is actually in the system. Tevake and Targalid are both giving you very solid and well-intentioned advice -- that's why it's important to drain both case and reservoir and refill accordingly (many threads here to help you w/proper procedure to avoid mistakes). We understand you're an experienced wrench. But you're here asking for feedback because you don't have much 911 experience -- why ignore it? HTH Dale |
Dale, im not taking it personally. That is the trouble with posting, you cant tell the tone of voice. I was honestly asking. I like to understand the reasons for things so I can figure out how things work.
I was just curious as to why the dipstick is wouldnt be an accurate reading. Thanks for clearing it up for me. looks like I ll drain it all and then start over. Thanks Marc |
Good deal. Lots of folks who come here for advice are just looking for the "what to do" and not really the "why that way instead of this way" kind of response; I'll try to do better.
I don't recall from your other post; did the PO leave you with an owner's manual and/or Bentley? Lot's of help there on the peculiarities of the 911, especially for a dedicated gearhead ;-) |
My PO or, more likely, PPO's mechanic, must have tried silicone for gaskets. Here's the thermostat hole. http://forums.pelicanparts.com/uploa...1307216051.jpg I found cellophane-thin bits of clear stuff in too many places to be comfortable last time I had the engine out. But nothing seems blocked. And on the oil level thing... yeah gotta be checked warm at idle. If you change the oil and re-fill it (dino, not synthetic), search for how many quarts to start with -- or someone please chime in. As I recall it's like nine to start and then warm up and check at the stick??? I'd look for confirmation from experts on that. Shawn |
another update: I had the battery on the charger for the day and it was just toast. So off I went to get the new battery. Installed the battery and the gages all lit up. good, thats something. headlights work. good. you have to take the little things where you can..lol and so on to the final test. does it turn over? YUP :) I took car of the oil as well when I was out getting the battery so based on the other thread, I think im good there. So it turns over but wont start, At least its progress. However, turning this engine over a few times and it already started leaking. and its new oil leaking. It look like mainly its coming from between the cylinders and the heads. Im not sure what the stud sticking out are rigth at the bottom of the head, they almost look like a zerk fitting. Basically, they are all covered in oil already from just turning the engine over. Pics to follow.
I do have a question, what do you guys think the validity of doing a compression check on a cold engine would be? I know they are supposed to be warm when you do it. do you think it would just be way off and not even worth doing? If its ok I can do it now and know if I should keep messing with it. If not, then I have to start hunting down, spark, fuel, air mixtures, crank sensor, etc. So pics of the leaks so far.. drop between the head and cylinder http://forums.pelicanparts.com/uploa...1307224065.jpg Oil around those strange studs..not sure if its leaking from them or between the head and cyl right above it. http://forums.pelicanparts.com/uploa...1307224162.jpg http://forums.pelicanparts.com/uploa...1307224197.jpg http://forums.pelicanparts.com/uploa...1307224234.jpg |
unfortunately I have no manuals for this car. :( Im going to have to buy the bentley ones for it soon. |
Cold compression test is OK, and better than nothing. Most the tests I have done has been on cold motors.
The "strange studs" are air injectors minus the manifold to the smog air pump.
I'd leave them in until you are ready to replace with plugs. If you need to pass smog where you live you'll need a few more parts. |
"However, turning this engine over a few times and it already started leaking. and its new oil leaking. It look like mainly its coming from between the cylinders and the heads."
There are no oil paths between the cylinders and the cylinder heads, thus the oil could be dripping from above or somewhere else. Follow the suggestions and clean/remove existing oil from the engine exterior, then crank engine while observing top and bottom of engine to ID the source of the oil leak. While it may be common to perform a cold compression test, it's also less accurate, but it's better than speculating (guessing). Sherwood |
last update for the night..So I got it to run..well sort of. I was sorting out what was going on and the spark was there so I checked the fuel. I can spray some fuel in the top of the air cleaner and it will run for as long as the fuel in there lasts. so it would appear i have a fuel problem. so tomorrow I will be checking fuel pump, relay, DME relay, fuel filter, fuel accumulator, and such. Any other quirky things I should check into while im diagnosing?
Thanks for all the help so far. Once, I get it running I can do the accurate compression test and then continue to track down oil leaks. |
2.7 motor no DME relay to fiddle with check the fuel pump runs by taking off the air filter and push up on the air flow meter arm with the key on you will here the pump come on and go off when you let it down you can also here the injectors spraying fuel. I would check the fuel filter and hook up a gauge and check fuel pressure by the rear relay panel there is a spade connector that is I think brown/black wire that when it is unplugged the pump runs continuously good luck.
If fresh oil is coming from between the head and cylinder, that is a sign that there is a head (gasket) leak – usually from pulled or loose cylinder head studs and nuts. When the engine sat, some of the oil drained back into the engine and some eventually found its way into cylinders. As soon as you cranked the engine, the compression forced some out past leaking head gaskets (CE rings). I suspect you can get the engine running with this condition. You will have compression leaks. The good side is that you can then better diagnose the condition. When you have the valve covers off, take the long end of a 10 mm Allen wrench and see if any of the 24 head nuts turn with ‘finger pressure’. If any turn, you probably have a head stud issue. If you tighten the nuts (following the Factory procedure), do not tighten them to full spec. If any continue turning even a bit without getting tighter, STOP. You are just pulling the magnesium threads in the crankcase. A cranking compression test will give you some useful information. A cylinder leak test will tell you more – you will hear the air escaping between the cylinder and head. You will also get more accurate results after the engine has run a bit, blowing out the excess oil. Best, Grady PS: Great pictures, keep them coming. G. |
| All times are GMT -8. The time now is 12:33 AM. |
