Ignition upgrades?
For an 8.5-1 comp ratio carbureted 2.7 rs motor, what is the ignition upgrade of choice? I like the electromotive hpv1 (obsolete) but still effective, or an MSD 6al box ?
Your thoughts please.
Car is set up aggressively, but will not see track time, just canyon bonsai runs.
Thanks for advice,
Kevin
Old 06-06-2011, 08:04 AM
Max Sluiter
Flieger's Avatar
I would just stick with the stock Bosch CDI and points. You could try an optical trigger or a magnetic pickup but it seems like they inevitably have problems. The points need maintainance/replacement at intervals but seem to just keep on working.
Old 06-06-2011, 10:10 AM
tobluforu's Avatar
Stock seems to work pretty damn well and I can't believe I have the org. CD unit in my car-that just amazes me. But I do have a crane fireball coil which I only installed when the org. coil gave up the ghost over 10 years ago.
Old 06-06-2011, 10:30 AM
You'll get about as many "thoughts" as there are Pelicans.. I run a 6AL unit on my car.. I have it mounted under the driver's seat.. I noticed an immediate idle qualiity improvement.. If you choose that set up, make sure you use the proper coil, depending on where you mount it.. If you have a point distributor, I'd use a Pertonix unit, I've had very good results with these units over the years.. If you are concerned about failure, put your points in the glove box; it's easy to change back. If your 6AL fails (rare) you can get one at about any local parts chain store.. Also, I would search the forum for previous threads and read up other's experiences..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-06-2011, 03:29 PM
Banned
I have a msd6al, with a new JBracing distributor. It's a pretty slick unit. It's just like the one for a twin plug, but it is for 6 plugs.
It is entirely adjustable for the advance curve and has a magnetic pick up.
Works good.
Old 06-06-2011, 03:53 PM
carbs and an early S cam should have a distributor recurve from CIS curve imho
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-06-2011, 08:06 PM
