joehahn's Avatar
Post Turn signal "flasher" where is it?
Finally tackling the peculiar blinker problem (varies from 1 working to both in unison, to no action at all). I have read all the archived posts and am pretty sure I know what procedure to use (check grounds, contact points, etc) but I am wondering about the "flasher". I thought that was a generic term for the blinker itself but many people refer to a bad flasher. Does this mean a "flasher relay?" If so, where is it? How do I check it?
Thanks,
Joe 68L
Old 07-16-2001, 09:44 AM
Stay away from my Member
campbellcj's Avatar
Post
I'm not sure about your early 68 car, cuz quite a few things are a little different (or a lot different), but on my 70 it's a little rectangular relay box behind the dash gauge panel. It's behind the fuel/oil combo gauge (left side) IIRC.
They do go bad. Unfortunately the part is around $35, but it's an easy fix.
Chris C.
Old 07-16-2001, 09:52 AM
Post
$35 for a flasher. whoa. i would try to modify a $1.50 flasher. they are a very simple device. i'm sure the contacts could be modified to fit the port.
Daryl 964 Targa
Old 07-16-2001, 10:51 AM
joehahn's Avatar
Post
...what's it look like?
Old 07-16-2001, 10:59 AM
campbellcj's Avatar
Post
I used to have a good picture of one (in the car) but I can't find it...there's no pic on the Pelican catalog either.
The flasher relay is just a small rectangular box -- probably silver colored (metal) if original or black plastic if newer -- about the size of a "D" flashlight battery or so.
Easy way to find it is by sound (if it works at all) - the clicking sound when your blinkers are on comes from the relay. Follow the sound.
Chris C.
[This message has been edited by campbellcj (edited 07-16-2001).]
Old 07-16-2001, 08:21 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Post
On my '66 model, both the turn signal and flasher relays were mounted under the footboard, right above the brake pedal.
Marc
Old 07-16-2001, 08:33 PM
