Can Someone Post a Picture of These Front Tow Hooks Installed.
Can someone please post a picture or direct me to a link where I can see how these front tow hooks are mounted. Thanks for your time.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 06-04-2011, 08:47 PM
1980 911 SC
As shown in Pelican Parts tow hook section.
Life's a Beach
Old 06-04-2011, 09:01 PM
Thank you very much, I should have checked there first. Can these be installed while the car is on the ground?
Best Regards,
Alex
Old 06-04-2011, 09:06 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
yes, but its a little tricky if you have a lip spoiler as you dont have much access and youll have to wedge a prybar in between the a arm and the body.
Old 06-04-2011, 09:17 PM
1980 911 SC
there are several threads on towing you might want to read first before going this route.
Life's a Beach
Old 06-04-2011, 09:18 PM
rattlsnak's Avatar
geez, was that car dragged around by those hooks? They are made more for trailer tie down, or to hook a winch up to and pull it on a trailer, not so much to be pulled down the street by them..
Old 06-04-2011, 09:20 PM
80-911SC's Avatar
what he said ...... those are tie down points not tow hooks
Old 06-05-2011, 12:46 AM
moneymanager's Avatar
Using those for towing will likely bend the front valence or destroy the rubber air dam if you have one.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 06-05-2011, 04:41 PM
boba's Avatar
That damage does no look like it is from towing, it looks more like the car bottomed out at speed. That took some force.
Old 06-05-2011, 04:51 PM
KNS KNS is offline
In the photo it looks as though the metal had been weakened by rust as well.
Kurt
Old 06-05-2011, 05:01 PM
Taking it apart is easy
Jerome74911S's Avatar
I don't recall the thread that the photo of the broken tie down hook first appeared in, but as I remember the story the damage happened in "normal" use, except for the issue of unseen rust. I think I also remember that serious body work was done to correct that rust.
Then again, I could be wrong, because what I think I remember doesn't explain the break in the hook itself.
Anyway, I need new tie down hooks, because the original ones are ground down to nothing and broken.
Are those Rennline hooks the best out there?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 06-05-2011, 05:58 PM
Check at a salvage site and find some good used ones. Then you will be "original"
Old 06-05-2011, 06:15 PM
Formerly known as Syzygy
Canada Kev's Avatar
I put a set of those on in the event I ever needed a winch up onto a deck. And I thought the extra bit of protection from hard things like drive way curbs and the like would be good. However, there was something I read here a while back that has me thinking I'll replace the original hooks. Jeff Alton was talking about how a set of those caused some big issues after hitting something hard at high speed. With the original hooks, the problem would have likely not been so. Probably best to talk to him or do a search here for more info, though.
Kevin
Old 06-05-2011, 06:32 PM
If your car is at euro height or lower, you will not like how many times they hit. I modified mine by heating them up and then bending them 45 degrees. Much better.
Old 06-05-2011, 06:53 PM
Thank you everyone, I should have been more clear. My intention is to use them as tie downs, I hope this is still within the scope of these units. Best Regards.
Old 06-05-2011, 07:12 PM
Who is the supplier of those tie downs you intend to use? They are shaped differently from the Rennline version, but are obviously similar.
Jerome
Old 06-05-2011, 07:20 PM
