Are Drop Link bushings replaceable?
Hi,
Are the drop link bushings themselves replaceable? Or should I just replace the entire pair. ('87) I didn't see / couldn't find replacement parts from our host, nor could I find a separate part in the PET. I ask because I thought I saw a thread regarding the removal of the bushings - but maybe it was for a different year. No probs now, just planning. Thanks
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Pretty sure they are sealed in the housings... (someone correct me please if I'm wrong)
I replaced the entire drop-link (easy job).
'65 Porsche 912 (painted dash) #451232 '65 Porsche 912 (painted dash) #451425 - 13 days younger '78 Porsche 911SC - Resto garage queen |
Member 911 Anonymous
Hey Dan,
If you had a press and proper ID/OD bushings, I see why not. You could also upgraded to a polymer unless you want to stay concours???
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Definitely replaceable. I bought rubber ones (Weltmeister I think) but I couldn't get them in without a press. Rather than take them to a machine shop, it was easier for me to make replacements from Delrin since I have access to a lathe at work. I think I bought the rubber ones from our host.
Steve B. 1972 911t 1999 328is |
cycling has-been
a bench vise with a 4" jaw opening will also work.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Thanks guys,
Would anyone have a part number for them? I searched to no avail.
WUNDERWAFFE
I replaced these about 6-7 months ago, I did not fit under the car nor did I have ramps. I just put both sides on jack stands and replaced them, It wasn't too bad. These are the part #s
good luck bro ![]() 930-333-071-00 930-333-072-00
Charlie 1986 Carrera |
Thanks Charlie , but I thought I could just do the bushings. Is there a number available for them?
Jim, yeah, this is just for street, but poly doesn't matter if the price is right. The drop links themselves are 50/ea. I was planning to do the rear suspension, but I might drop the rear sway in order to tackle the tunnel fuel lines, and thought "while I was in there".
WUNDERWAFFE
No, not for our style of drop links bro
Well, if it is not a daily, why nut press or carefully cut them out and measure them???
Or at least measure them from the inside of the drop link and the sleeve.
Thanks Charlie & Jim.
I'm probably just going to buy the full assys I guess. I don't trust my fab skills, or should say, I don't know what the bushings look like (yet). This is just for planning for the winter already, but I might get impatient if I drop them for the fuel line sooner than later. Thanks for the help guys. I do appreciate it!
Honestly, if I was replacing them, I'd rather pay the $130 for the adjustable set that is available here vs. paying $100 for the two non-adjustable ones...
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
I'll look those up - thanks Mike.
Drop links
I have an almost new set of Tarret engineering front drop links that I will sell for 100 bucks. They are adjustable and ran the whole setup on my 930.
Pm me if your interested. Thanks, Kevin. |
PM sent
