dazed and confused
low hum when turning left...
...low hum from left rear only in left turns and starts as the steering wheel moves just off center. Sound increases with decreasing radius as the G's increase. Wheel bearing? CV joint? Jacking up car and pressing in on top and bottom of wheel shows no movement. Any thoughts on how to diagnose appreciated.
89 Carrera 3.2 Targa 2011 BMW 335d 2013 BMW X3 3.5 80 911 SC Weissach Coupe (Sold)
Spiderman
Sounds like wheel bearing noise to me. Seems thats just how guys at my shop described it would be when it happens. I think rear CV noise would be more difficult to hear unless there all the time. Unfortunately two bearings, very close to one another.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
I´d say its the bearing too. The 12 O´Clock 6 O´Clock trick doesn´t always identify it
That was how mine began, it got progressively louder over time, until I finally diagnosed it as probably a bad wheel bearing. Which it was. Replaced both rear wheel bearings, all is now well. BTW, there was no lateral movement on my wheels either.
Jerry M '78 SC |
The other day we used a long wood axe handle (a 1" wood dowel or similar would be better) pressed on the arm near the bearing and held against an ear, comparing car with suspected RWB noise and another 3.2 with known good bearings, you could definitely hear the difference, could also hear the difference by rotating the wheel jacked up. There are a number of threads here on how to pull the bearings out, a puller can be made from parts purchased from OSH. If you are not careful while installing the new bearings in you might be doing it over again soon. Be careful how you use a hammer if used at all. I pulled my bearings in, but you don't have to if you can apply force only on the outer race.
gruppe f
Mine did the same thing, and it was the bearing. Honestly I couldn't really detect the problem by trying to rock the car back and forth. If it's not making much noise, you'll have time to attend to it before it becomes critical.
Mike Hinton '06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine, '74 914 1.8 Marathon Blue, '64 356C Aubergine |
Quite a few threads here on replacing the wheel bearings (bastard of a job I might add!).
Thanks to Pelican, the job got done and the noise of the engine is the only thing I hear now!
'65 Porsche 912 (painted dash) #451232 '65 Porsche 912 (painted dash) #451425 - 13 days younger '78 Porsche 911SC - Resto garage queen |
dazed and confused
brought it to my wrench...
...the guy I use when I'm stumped (he did the PPI too). He put it on the lift, (I gotta get one) while his assistant climbed up, started the car and ran it up in second gear then idle, while he took his stethoscope and listened to both bearings...pronounced both OK, but thought the right rear might be worse than the left (?) We took it for a spin, and while he could hear the groan, didn't think it was so severe as to warrant replacement. "Enjoy the summer", keep driving it, replace them next year (winter). No charge. OK then! (I've read all the threads on DIY replacement and am ready with bearings bought, but would rather see her on stands off-season rather than now!)
Thanks for all your inputs!
Does it 'groan' whilst straight line driving, under load etc other than cornering?
I found my CV's were very 'pitted' and caused a groaning noise whilst normal driving without turning. Changed them, noise gone! Changing both bearings should take you about a weekend, changing bearings and 4x CV's not that much longer, so no real need to wait till winter if the noise is anoying you that much. You will need a few tools (as well as some that you will have to make if you dont have the Porsche tools) and as per the threads you have already read, you will need patience and a few beers! Oh and BTW hide the swearing jar... you'll be broke!
dazed and confused
FIG,
Thanks for your input, however I'm still not sure I want to tie up three weekends under the car...(projects always take me triple the time!)... I'd rather be sailing...New England summers are short enough! No noticeable groan going straight...only the left turns. Any particular tools I need to buy?..thought those DIY tools listed in these threads pretty much summed it up.
Member 911 Anonymous
Ball Joint Remover ( not pickle fork but the screw press type at HB )
Spanner Wrench ( but a short socket will work to remove strut nut, just take care and watch the fender ) Punch Tool ( or piece of steel, just leave nut on end of joint bolt flush the use a Sledge ) Penetrating Oil Torque Wrench Ball Joint Socket & Impact Wrench ( Pipe Wrench with cheater bar will work just as well ) Brake Fluid ( you will need to disconnect the brake line, place a 24" blokc of 2X4 and depress the brake to prevent fluid leak, then bleed when done ) Most tools can be rented for FREE at a FLAPS Take care when removing the strut, DO NOT LET IT HIT THE UNDERSIDE ![]() Beer ( Nice reward at the end ) ![]() Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-08-2011 at 06:26 PM.. |
I also used a slide hammer which was great, along with gear pullers (for the remaining bearing piece).
Not for the faint of heart, but rewarding none-the-less. Take your time and TRY to enjoy the ride.
dazed and confused
Thanks, Guys. I keep this thread bookmarked and go through the tool list when I revisit the procedure. I'll post my experiences when I tackle this.
Cheers!
dazed and confused
..cracked sway bar mount? Tires?
hum still there...would like to address it the simplest way possible (obviously). Searching other threads reveals tires as a possibility (old Dunlop 8000's)...Left rear worn to the wear indicators (but why would this cause hum in left turns only?) or cracked sway bar mounts (PO had originals replaced)...not sure how to inspect these or what to look for?
Any thoughts appreciated as always.
If only the left rear is worn it could indicate an alignment issue. This could also explain why then the noise appears on left turns. Sounds like you are due a new set of rear tires. Get that done and realinged and see what happens to the noise
good point, IME tires can make all sorts of strange noises sounding like bearings going bad/etc. you might try borrowing tires for a few minutes, if another Pelican or other with tires that fit and see if the noise changes
dazed and confused
Thanks guys. Not sure I can find local Pelicanite to loan me tires but I do need to get on with replacing at least the rears. However I first need to roll or trim the front wheel lips and lower it. My dilemma is whetherr to increase the wheel dia to 17" with existing BBS centers (see garage pics), swap to Rotos or just leave it alone...I know there's more than one right answer but opinions are welcome!
