Need help identifying a part
1982 3.0 UNDER THE AIR BOX ON THE DRIVERS SIDE OF THE MOTOR THERE IS A SENSOR DIRECTLY UNDER THE MOUNTING BRACKET FOR THE AIR BOX,CAN SOMEONE HELP ME IDENTIFY THIS SENSOR? OIL PRESSURE? OIL TEMP?
Tim
1982 911 SC----SOON TO BE TURBO 911 SC |
83 911 Production Cab #10
Any chance to post a photo?
Did you check the CAT? It should be in Main Group 1: Engine Go to New Part Cat and click on "Can't Find It" (photo of a cylinder head)
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Sounds like the cold start injector with a blue connector on it.
Bruce |
I will post a pic tomorrow. It had one wire and if i remember correctly it was blue. I am chasing an oil leak back in that area. Pretty bad leak
