how do you bypass the ignition delay relay?
does anyone know which of the 4 terminals on the ignition delay relay you jump together to disable the thing?
i am sick of the annoying stumbling run on in my 930 and i have read you can jump 2 of the wires at the ignition delay to stop it.
the pins are lettered and numbered: L, S, 30, and 31.
does anyone know which ones you jump/connect together to stop the run on?
don't want any opinions on it, don't care if the injectors are leaky, just want it to stop.
thanks in advance for any helpful information.
Old 06-11-2011, 02:03 PM
remove the relay and make a jumper using two flat spade terminals and jump the two terminals in the plug that are closest to the engine.
206 637 4071
Old 06-11-2011, 02:43 PM
Thanks for the reply John, and I read that and saved it a couple years ago.
Do you mean spade terminals L and S that are closest to the fan housing and next to the plastic male locating pin to keep the relay plug from being installed the wrong way?
On my car both of those wires in the relay plug are red with a white stripe.
Just don't want to do the wrong ones and melt some wires..
I'm putting in a small toggle switch on the relay panel wired to the two wires going to the relay plug so i can flip the switch one way and the motor stops immediatley when I turn off the ignition key and then flipped the other way it will be as it is now... stumbling run on that sounds more like an abused choked up third world yugo running on the lowest octane crap gas on the planet.
thanks again
Jim
Old 06-11-2011, 03:14 PM
Jim
that's correct.
206 637 4071
Old 06-11-2011, 03:23 PM
