Engine hose clamps - reusable?
I'm planning to replace the ICV and check several other items (for vacuum leaks), and have found those hose clamps a little confusing. They look to be 'one-shots', in other words, installed at the factory (with maybe a special tool) and not reusable once removed. Is that correct? Can I replace with conventional worm screw type? Or should I track down the originals?
Thanks.
'87 Black on Black Targa - my second BLACK Targa... didn't learn the first time. __________ '72 El Camino - 550HP pro-tourer |
Member 911 Anonymous
Yes, unless thrashed, if they are OEM, keep them SAE just don't fit right and the sharp edges tend to cut the hose, another issue
![]() BTW that upper hose on the ICV is NLA so be very careful
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Oetiker is the name; needs an Oetiker-appropriate plier to crimp them.
e.g. Hose, Tube, Fittings & Valves from MSC Industrial Supply Co. Sherwood |
Understood, thanks!
But how should I remove them? Would I need the Oetiker-appropriate pliers to remove?
Sherwood |
Buy an Audi and you'll get very good at it
Chris '87 Targa |
I just bought Tile Nippers for $7.00 at a local hardware store. If this ear clamps are the same design, once I squeeze it at the numb it should release.
Will be changing the PCV and hope to reuse the ear clamps if not SAE goes on.
