Wer bremst verliert
JohnJL's Avatar
What size and thread are big red caliper hard lines?
I am installing big reds (993TT fronts 964Turbo rears) on my SC that had front A and rear M calipers. I notice the hard line fittings do not fit the new calipers. The threads are the same but the screw bottoms out before the line seats in the caliper.
The new calipers are in a different position to the originals, so I suspected I might have to replace the hard lines anyway.
I was thinking about using one of the longacre kits to redo the system as everything other than the master is still original to the 83 car. I was considering this one:
http://www.longacreracing.com/instructions/text/45215PI.pdf
Longacre Racing - Online Catalog: Electronic Wheel Scales, Gauges, Pyrometers, Chassis Setup and More!
The kit states it does not come with the caliper fitting.
Whats the proper fitting for the caliper? And do I want AN3 or AN4.
I guess for that matter, what is the size of the master fitting also since I'll need to connect that to the longacre kit.
Thanks!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-13-2011, 07:13 PM
Northern Motorhead
wildcat077's Avatar
Not sure if they are the same as my 996TT calipers but i had to fabricate new hard lines anyways because the original 911 ones were too short,but i used the same fittings on my 996TT calipers.
I can't see why the fittings would be different ...
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-13-2011, 07:24 PM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
the fittings are the same. metric bubble flares on the lines with m10x1 threads on the fitting.
SOLD: '87 Carrera
Old 06-13-2011, 07:40 PM
Wer bremst verliert
JohnJL's Avatar
I promise you the nut on the flared fitting bottoms out in the caliper before the line pinches. It looks to me like a banjo fitting is called for.
I bought the kit from VCI but I did not receive any hard or soft lines. I've let them know the parts are missing and am awaiting a response.
Old 06-13-2011, 07:43 PM
Northern Motorhead
wildcat077's Avatar
I think you may need to adress Bill Verburg on this one,he is the resident brake GURU on this forum ...
If anyone can answer you,he's the one !
Cheers!
Phil
Cheers
Phil
Old 06-14-2011, 03:20 AM
Bill Verburg's Avatar
Thanks!
VCI should be able to set you up
but anyway the fittings are 10x1.0 and the line for a 911 is 3/16"(4.75mm)
there are 2 ways to do it
1) with a hard line from the caliper to the strut boss, then a flex line to the body lines
2) 1 longer flex line from the caliper to the body lines but held at the strut boss to prevent whip.
Bill Verburg
Old 06-14-2011, 10:53 AM
Wer bremst verliert
JohnJL's Avatar
Thanks Bill.
VCI has lines on the way.
Old 06-20-2011, 06:50 PM
