Removing side mirrors
I've disconnected the side mirror assembly except for the wiring. There doesnt seem to be a connector between the mirror and where the wiring exits the door toward the trunk. Do I possibly need to remove the mirror glass to access the wires? Otherwise it looks like I need to remove the door to get to where the wiring goes thru a grommet into the trunk-not a good design if this is correct. Suggestions?
Old 06-15-2011, 01:07 PM
Flat Six
Flat Six's Avatar
Year?
On the Carreras (and SCs I think), there's a round 6-pin electrical connector behind the door card.
HTH
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-15-2011, 01:46 PM
Its a 1987.
There is a 6 pin connector in the trunk. Are you suggesting I need to pull that connector thru the grommet on the body, then thru the grommet in the door? Doesn't seem like a good design if so.
Old 06-15-2011, 02:18 PM
