mikesride's Avatar
Had to run 10% ethanol then hard start??
Was running low and had to fuel up at a station that uses a 10% ethanol blend. Car ran fine but then after being parked for three hours it didn't want to start. Had some Dyson 104 octane boost in the garage and added some to the tank seems to have helped.
Is this the issue all the guys who complain about the ethanol blends are talking about? I try to avoid it solely because of what I have read here. Is it possible that I will feel any further negative effects after this tank runs through? (1982 sc with cis)
As always guys/girls thanks for any input or info I would be lost without your help!
I've driven alot of crap to get here man!
Old 06-26-2011, 09:32 AM
mack6820's Avatar
I ran on ethanol for years in Virginia because you cant get regular gas there. I never really had any issues but I do notice a smoother running engine now that I'm in Oklahoma without the ethanol.
83SC, CIS
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 06-26-2011, 09:37 AM
pete3799's Avatar
I doubt the fuel is your problem.
All i can get has ethanol in it....no problems so far.
Sounds more like a residual fuel pressure problem.
Got a test gauge?
Pete
79 911SC RoW
Old 06-26-2011, 09:41 AM
mikesride's Avatar
thanks guys
Yeah guys it felt just like it did before I replaced the fuel accumulator last year. The real strange thing is that it seems OK. Next step is to search threads for checking pressure drop and start there...
Old 06-26-2011, 09:52 AM
Have to use it in South Carolina, also... No problems with vehicles, problems with small engines~ mowers, chain saws etc..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-26-2011, 10:09 AM
You might want to replace the fuel pump check valve if this persists; its not an ethanol issue.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-26-2011, 10:44 AM
Fuel pressure.......
Mike,
Check the residual fuel pressure. Don't blame the ethanol, it has nothing to do do with your engine's failure to re-start.
Tony
Old 06-26-2011, 09:06 PM
BKC BKC is offline
I finally said, "Screw it", and filled up with Shell in my carbureted SC. Didn't really think much about it but now that you mention it the car failed to fire right up when warm with throttle floored as recommended by our host in his book. It started fine but didn't immediately start as per normal. We'll see if the carburetor seals fail!
As a side note, I've been taking the car to red line on a regular basis and its helped significantly with my smoking under hard acceleration due to running rich. So, hopefully no more fouling plugs! Not used to driving a real sports car.
Brian
Anacortes, WA
81 SC
Old 06-26-2011, 10:31 PM
