schumicat's Avatar
First engine drop, and clutch diagnosis
With much help from fellow Pelican Shawn (NOLASC) and the 101 Projects book, the first engine/trans. drop on my car was completed. I posted earlier that my first 911 track day ended abruptly when the clutch let go. Today we separated the engine and trans. As you can see in the attached photos, the clutch disc basically blew up. It looks like it was worn down to the rivets.
Many thanks to Shawn for his help, which required braving the brutal heat and humidity. I wouldn't have been comfortable doing this alone for the first time. We did the drop under carport in my backyard using a jack, 2 jack stands, and a bunch of wood.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-16-2011, 06:38 PM
schumicat's Avatar
Old 06-16-2011, 06:45 PM
MBruns for President
JeremyD's Avatar
you killed that clutch! Nice job
Old 06-16-2011, 07:07 PM
UnRegistered User
billybek's Avatar
Bummer that it wasn't just a cable but it looks as though you have enlisted some good help!
Bill K.
Old 06-16-2011, 07:10 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Well, there's your problem right there.
I hope you had a big honkin' fan blowing on you working outside in NO.
Old 06-16-2011, 07:16 PM
NOLAsc's Avatar
Dude... a normal clutch is supposed to look like this:
But yours looks like this:
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 06-16-2011, 08:10 PM
NOLAsc's Avatar
(Sorry y'all. Hit the wrong button, I guess, on the post before)
This seems to explain your trouble. I hope there is nothing else going on.
Glad to help.
Shawn
-- William Faulkner
Old 06-16-2011, 08:15 PM
JeremyD's Avatar
You usually see the rubber centered ones explode - usually doesn't happen to the spring centered ones.
Old 06-17-2011, 06:07 AM
