LED Lighted Key Head
Just did this. Works fantastic ! for about 18 dollars and a trip to Radio Shack
you get twice the light. Rennbay.com : |
Northern Motorhead
Thanks for the tip ...
Going to look into it as well for my keys! Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Recreational User
Thanks! It's on my to-do list.
RETIRED
SO it needs two batteries because it has a higher output bulb?
EDIT: WARNING......The RENNBAY tutorial has the polarity backwards.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 05-30-2011 at 08:02 AM.. |
Almost Banned Once
No... A LED (light emitting diode) is a solid state device that uses much less power than an incandescent bulb but the LED he used in the tutorial works with 7.2 Volt (3.6 x 2 = 7.2v)
The same LED won't work with 3.6v. Well It might but it may be too dim. Note: 5mm LEDs... The guys at Radio shack should be able to help you get the right one to suit the voltage of the two batteries. BTW: The batteries would last for years and years of constant use. ------------------------------------------- OK... This is a great tutorial. The incandescent bulb fell out of my lighted key about 8 years ago. ![]() Thanks for posting.
- Peter |
muck-raker
I cleaned all the contacts, replaced both the battery and the incandescent bulb....and it STILL doesn't work. AAARRRRGGGGGHHHH
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Almost Banned Once
Imagine not opening you key for years and years, ![]() I'm on my way to Jaycar (Radio shack equivalent)
- Peter |
Member 911 Anonymous
Hey Kidrock,
Move the contact around to insure the contacts don't touch the same surface of the battery (++ or --). Test before you re-assemble. or Mail it to me and I will fix it for you :-) Stay well Brother! J
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Can you let us know what the make and model number of the LED is and what batteries you are getting........at least I'll know what to ask for at Jaycar..... ![]() Cheers, Geoff.
1984 911 Carrera....... |
Almost Banned Once
Geoff
Will do.
- Peter |
R&D guy
Location: the border between the states of inebriation & confusion
Thanks, chuckr
Interesting link. I thought that in order to substitute an led for a bulb, one would have to add a resistor. Ok, I get it - by using (2) #389 batteries, the source voltage is 2 x 1.55v = 3.1 v, and this Radio Shack led is 3.2v typ., so the current limiting resistor would be about 1 ohm if the led was run at the battery max voltage. 1 ohm is in the range of typical contact resistance. I wish I knew this when I needed a replacement bulb for my old lighted Saab key and the bulb was NLA. |
One thing to mention... the instructions in the tutorial are incorrect regarding the led polarity.
the longer lead off the led goes on top of the battery. The comment at the end of the post brings this up. |
That's cool. Another job for a rainy day!
Pete Porsche, there is no substitute! 911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv |
The copy I have also contains this information:
5mm White (or any other color) LED 3.6 volt, 20ma 1100mcd RadioShack # 276-320 I found the Radio Shack LED (p/n 276-320) was not available at any store nearby, but was able to order 20 of them off Ebay, shipped from China, for LESS than what 1 costs at Radio Shack For those of you interested in the ebay seller I purchased these from, the sellers name is hktaiyuen and the EBAY store link is The LED description I purchased is : 20x 5000mcd 5mm White LED Ultra Bright Free Resistors. That gets you a qty of 20 LEDs, and the resistors are not used. The current price is $0.99 and $4.00 shipping. I checked the ebay site and its still there, although there is currently one bid for .99 so you would have to pay a bit more.
Dennis |
yep, im slow in the head
nice lill mod
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something |
Did it...
Awesome :-)
'65 Porsche 912 (painted dash) #451232 '65 Porsche 912 (painted dash) #451425 - 13 days younger '78 Porsche 911SC - Resto garage queen |
Allright, I'm not an electrical mental giant and obviously either are the folks at my local Radio Shack. I'll have to rely, (thank you in advance), on the Pelican brain trust. This is what I was given, will it work...
2 - 1.5 volt watch batteries. They are 389's as the article said 1 - 5mm LED 3.2 volt - 20mA- 6.2 cd, (what ever that all means). They said all watch batteries are 1.5 volts. Again thank you.
O2 In Sully We Believe Last edited by Buckterrier; 02-17-2011 at 02:41 PM.. Reason: more info |
