Why did I remove the bonnet to replace spring plate bushes?
This is how it happened:
New spring plate bushes became new trailing arm bushes New trailing arm bushes became new sway bar bushes New sway bar bushes became new front suspension bushes New front suspension bushes became new ball joints New ball joints became new front hub bearings New front hub bearings became new rear hub bearings New rear hub bearings became new e brake and rotors New e brake and rotors became refinished trailing arms Refinished trailing arms became refinished spring plates Refinished spring plates became refinished / replaced rear suspension Refinished / replaced rear suspension became refinished front suspension Refinished front suspension became refinished underbody Refinished underbody became refinished wheel wells Refinished wheel wells became refinished Fuchs Refinished Fuchs became removal of A/C Removal of A/C became all new or refinished hardware All new or refinished hardware became rebuilt calipers Rebuilt calipers became new brake lines New brake lines became restored master cylinder Restored master cylinder became refinished fuel tank Refinished fuel tank became refinished front trunk So, that’s why I had to remove the bonnet! Is this what is known as the slippery slope? PS. There is much more to this list but it was condensed to avoid too much reader boredom. I also should thank everyone who has so far supplied knowledge and/or parts to get me to this point, including some PP royalty Obligatory pic...
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
Nice work!
![]() It's for sure a slippery slope. |
Bird. It's the word...
There's a familiar view
John Forcier Current: 68L 2.0 Hotrod - build underway |
I'm sure it is John. I saw your trunk restoration project (before your complete dismantle and rebuild) and have made careful notes of the standard I have to achieve.
I'm only about 6 years behind you!
Not much of a slope - more like a sheer drop.
I really need to do this to my trunk but could not bear to have it off the road for the time it would take me to do it. :-)
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
I remember thinking 6 years ago; "I really ought to do the whole lot"
Detached Member
I don't think you had to remove the hood just to do that.
Hugh |
Thanks Hugh.
I wanted to clean up and paint the hinges as there were signs of corrosion where it mates to the bonnet. Also, it does make access the rear of the dash much easier as well as moving the LHS wiring out of the way. I plan on taping it up and suspending the wiring so I can get paint everywhere I want without lines.
I doubt this will be the last time the car ends up in some degree of disassembly. Be nice to get some years of enjoyment first.
I just got another cortisone shot in my elbow from my slipper slope adventure. Looks nice...
P-car no more 2000 F250 Powerstroke Crew cab "Growler" 2007 Honda Odyssey "The Bus" 2006 BMW 330i Manual 6 speed "The Sled" 1987 Mercedes 560SL |
My blog has got all the pics but I didn't want to upset Wayne and direct people away from this site.
Here's a small sample of the before and after of only 2 areas of the car:
Great Job. I've been following your blog ever since I stumbled upon last fall. All the work will definitely be worth it once it's finished.
Thanks Will.
I'll try and keep the progress going - hard with full time work, 2 young and all the rest. Really without these forums I wouldn't have known where to begin.
