Shaun @ Tru6's Avatar
Corroded Spark Plug Lead
of the 6 wires on my 86 motor, all are perfectly clean on the inside except for one.
is this something that can just be cleaned and reinstalled or is it indicative of a bad wire? or a bad plug? or it wasn't connected properly for some time?
clean and install? or make up a new lead with new connectors?
Tru6 Restoration & Design
Old 06-19-2011, 06:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Why not give it a shot, if it doesn't work, swap it.
'85 Carrera Targa
PCA/POC
Old 06-19-2011, 08:05 PM
The missing rubber boot might have prevented the corrosion.
Old 06-20-2011, 04:01 AM
I pulled the boot off for clear pics, it was on snugly, including the valve cover ring, like all the others.
I am curious what caused this.
I'll make up a baking soda slurry and try to clean it out but would rather just replace the line the more I think about it.
Old 06-20-2011, 06:19 AM
Flat Six
Flat Six's Avatar
Shaun -- Looks like a BERU end, yes? I have a couple of lightly-used spares . . . PM me if you need 'em
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-20-2011, 08:13 AM
AutoBahned
RWebb's Avatar
just replace it - wires should be replaced at some (long) interval anyway
maybe somebody pressure washed the motor?
Old 06-20-2011, 12:11 PM
Two different metals making contact leading to electrolysis?
Electrolysis
Electrolysis
Summary
Electrolysis is a chemical and electrical process. It occurs when two different metals are in contact, in the presence of a moist agent such as water. One of the metals is corroded away.
Old 06-20-2011, 12:16 PM
Dale
Dale, thanks so much for the kind offer, I really appreciate it! A friend of mine up the road has a few as well, so rather than put you out, I'll sponge off of him. Thanks so much though, this is what makes Pelican great!
Old 06-20-2011, 12:36 PM
Flat Six
Flat Six's Avatar
No problem; glad to help. If your buddy's don't work out just give me a shout.
Dale
Old 06-20-2011, 02:52 PM
Moisture. Even with the boots on, moisture still tends to get in.
Old 06-20-2011, 04:17 PM
