Like a walk in the park everyone..
Now I'm wondering if I can get it back in myself as well. Sorry.. No pics yet.. Enjoy, HFR_Racer
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
Detached Member
Let me be the first to say congrats! I pulled mine for the first time by myself last xmas break. Not terribly hard, but not like any other engine I've ever pulled. I used an engine hoist to lift the rear of the car versus getting it way up in the air with jackstands. Much safer I thought, and I had the engine hoist so I didn't need to buy the RV jackstands. Gotta love them Targas!
Hugh |
I'll be the second to congratulate you. Putting it back in solo isn't as easy, but doable.
Marv Evans '69 911E |
Back in New England!
Congrats!
I have this looming in my future...sometime in the next year. All of the threads here will help guide me through it along with the Bentley manual and Wayne's books. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Just don't be afraid. Even if the next to worst thing happens- you drop the engine on the ground- usually nothing gets very messed up. If the worst thing happens- you drop it on yourself- things get more messed up.
Wer bremst verliert
always throw the wheels under the car when jacked up for xtra safety. I put mine back in, awkward but nothin' but leverage involved.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Wow Hugh!!
That's a great idea. I have a engine hoist. But I have a question. Where exactly did you pick up the rear of the car? |
Detached Member
Take out the engine mounts and make a plug with a lifting eye hook that is bigger than the engine mount holes and mount underside. DON"T lift through the mounts themselves, they'll probably rip out.
Hugh Last edited by Hugh R; 10-12-2006 at 04:22 PM.. |
Thanks for the kudos..
Thanks everyone for the congrats...
I have a helper to put it back in tomorrow.. I just dropped it to clean it up, check for the common leaks, adjust the valves, etc.. I think I may need a shifter shaft seal and that's about it. I'm not seeing any leakage between the jugs and block so I hope this means no broken head studs on the exhaust side. Enjoy, HFR_Racer.
Licensed User
If you didn't already use one to do the drop, go buy an ATV jack for the reinstall.
All is well.. No broken studs..
No broken head studs found at 60k miles. Valves adjusted. Engine and transmission cleaned up and shifter rod seal installed.. Time to re-install..
HFR_Racer
Maybe I'm lost here.
